On Apr 4, 2012, at 9:42 AM, Pavel Masloff wrote:
> I would like to implement a simple command record, the idea of which is to switch its VAL to 1 and then back to 0. Let's assume we have got the following record:
> record (bo,"cmd:valve_trigger")
> field(PINI, "YES")
> field(DTYP, "S7plc")
> field(OUT, "@plc/0 T=UINT8 B=0")
> field(SCAN, "I/O Intr")
> field(ONAM, "ONE")
> field(ZNAM, "ZERO")
> Is there any straightforward solution?
Yes . . .
field(HIGH,"0.5")
where "0.5" is a floating point value representing the number of seconds to hold the VAL to 1 before resetting it back to 0.
(And you probably don't want the bo record to scan on I/O interrupt. More typically, output records are Passive.)
Steven Hartman
[email protected]
- [db] simple command ? Pavel Masloff
Re: Inspect Samples of CSS shows inconsistent SEVR Burkhard Kolb
Re: [db] simple command ? Tim Mooney
<2012>
<2012>
