1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Inspect Samples of CSS shows inconsistent SEVR
To: "Kasemir, Kay" <[email protected]>
Date: Wed, 4 Apr 2012 15:57:31 +0200
Am 04.04.2012 um 15:49 schrieb Kasemir, Kay:
> Hello Burkhard:
> On 4/4/12 09:35 , "Burkhard Kolb" <[email protected]> wrote:
>> of course your right. But as you say Inspect Samples is a debug tool -
>> with that I would like to see really what it gets from the database.
> Absolutely.
> Isn't that's exactly what it does?
> It shows what the data browser gets from
> * the Channel Archiver's network data server
> * an RDB-based archive data source
> * another data source that your site may have implemented
> * live data that the data browser has accumulated
> If you change the request type between "Optimized" and "Raw data",
> you can see the difference.
> If you zoom in far enough and your data source then automatically
> switches to raw data, you see that.
This would be cool - how far is enough? I have now about 5 samples in time on the trend plot,
nevertheless the Inspect Samples shows me many thousand samples and does not automatically switch
to raw data.
> It's the tool for debugging what the data browser receives.
> If you want to see where the data is coming from,
> you have to check who's sending the data:
> How is the Channel Archiver's network data server generating
> those samples?
> What is the data in RDB tables?
> There is a limitation in this client/server setup as to how
> far you can go:
> The data browser and its sample inspector just shows what it
> receives. It cannot see the underlying Channel Archiver index or data
> files,
> it won't show RDB tables.
> -Kay
DataBrowser "Optimized" data Re: Inspect Samples of CSS shows inconsistent SEVR Kasemir, Kay
Prev: Re: Inspect Samples of CSS shows inconsistent SEVR Kasemir, Kay
Next: Re: [db] simple command ? Hartman, Steven M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: DataBrowser "Optimized" data Re: Inspect Samples of CSS shows inconsistent SEVR Kasemir, Kay
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
