I would like to implement a simple command record, the idea of which is to switch its VAL to 1 and then back to 0. Let's assume we have got the following record: record (bo,"cmd:valve_trigger") { field(PINI, "YES") field(DTYP, "S7plc") field(OUT, "@plc/0 T=UINT8 B=0") field(SCAN, "I/O Intr") field(ONAM, "ONE") field(ZNAM, "ZERO") } Is there any straightforward solution? Thank you. -- Best regards, Pavel Maslov, MS Controls Engineer at Pulsed power Lab Efremov Institute for Electro-Physical Apparatus St. Petersburg, Russia Mobile: +7 (951) 672 22 19 Phone: +7 (812) 461 01 01
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
