Hi Kay,
of course your right. But as you say Inspect Samples is a debug tool -
with that I would like to see really what it gets from the database.
Typically somebody looks at the traces and finds some weird peaks,
then narrows down on this area and then wants to see the "real" values.
Regards, Burkhard
Am 04.04.2012 um 15:31 schrieb Kasemir, Kay:
> Hello Burkhard:
> You can of course request the raw data inside the data browser
> (in the trace's configuration, set "Request" to "Raw Data" instead of
> "Optimized")
> and then you'll see "Original" instead of "Interpolated" in the sample
> inspector.
> Or - as you did - export the raw data and view it outside of CSS.
> The sample inspector is more of a debug tool for seeing the exact samples
> that the plot
> uses to generate the graph. If it causes more confusion that good, maybe
> it should be hidden.
> Thanks,
> Kay
> On 4/4/12 09:24 , "Burkhard Kolb" <[email protected]> wrote:
>> Hi Kay,
>> I believe that the archiver and the data server do a pretty good job.
>> Misleading are only the Severity and Status values in the Inspect Samples
>> display in the case of Interpolated data. Maybe there should be a button
>> to
>> choose the raw data when one really wants to inspect data?
>> Burkhard
- Re: Inspect Samples of CSS shows inconsistent SEVR Kasemir, Kay
[db] simple command ? Pavel Masloff
<2012>
<2012>
