1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: asyn w/serial device pushing data
Date: Mon, 2 Apr 2012 12:16:35 -0700
I'd like to use asynPortDriver to connect to a serial device that pushes data when triggered by a hardware pulse.
If I use SCAN=I/O Intr and the pollThread() example code below from a previous tech-talk thread will my record be triggered to read every time there is new data?  Does this code mean my driver is constantly polling the serial port at a POLL_DELAY?
I only need to read, so can I call pasynOctetSyncIO->readIt() instead?
How will I know that the serial device has finished pushing it's data for that trigger?  Does asyn/pasynOctetSynIO->readIt() wait for the OutputEos in the serial buffer before returning the received message?  Or is asyn waiting to read sizeof(receiveMessage) characters?
> void myPortDriver::pollThread()
>     while(1) {
>           status = pasynOctetSyncIO->writeRead(pasynUserHMS, sendMessage, numSend,
>                                          receiveMessage, sizeof(receiveMessage),
>                                          WRITE_READ_TIMEOUT, &numSent, responseLen, &eomReason);
>           sscanf(receiveMessage, "TEMP=%f,CURRENT=%f", &temperature, &current);
>           setDoubleParam(temperatureParam, temperature);
>           setDoubleParam(currentParam, current);
>           callParamCallbacks();
>           epicsThreadSleep(POLL_DELAY);
Thank you in advance for any suggestions or comments.
Nia
Re: asyn w/serial device pushing data Eric Norum
RE: asyn w/serial device pushing data Mark Rivers
Prev: Re: casStrmClient.cc error: invalid channel identifier Tim Mooney
Next: Re: asyn w/serial device pushing data Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: casStrmClient.cc error: invalid channel identifier Andrew Johnson
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
