1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: What is void* puser in ca_create_channel
To: <[email protected]>
Date: Fri, 30 Mar 2012 15:57:35 +0200
On Thursday, March 29, 2012, Hill, Jeffrey O wrote:
> > How does this parameter have to look like?
> > Can I use a C-Struct with any member I want to have (even members which
> > are not for the CA, but for another part of my program)? Are there any
> > members which are mandatory? (like value or chid)
> A pointer to any data structure can be used. The CA library does not in
> any way access, or place any restrictions on the content of, this user
> application private data structure. The user application is of course
> responsible for allocation, initialization, maintenance, and
> de-allocation (proper cleanup) of this data structure.
> Use of void pointers passed to callbacks is an old technique which is
> roughly equivalent to a virtual function in modern software interfaces,
> BTW.
To give it some perspective, it is a low-level implementation technique for
what in high-level languages is automatically available when creating what
is commonly referred to as a 'closure'.
Cheers
Ben
Attachment: signature.asc
Description: This is a digitally signed message part.
What is void* puser in ca_create_channel Florian Feldbauer
RE: What is void* puser in ca_create_channel Hill, Jeffrey O
Prev: Re: another build problem with db dependencies Benjamin Franksen
Next: RE: What is void* puser in ca_create_channel Hill, Jeffrey O
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: What is void* puser in ca_create_channel Hill, Jeffrey O
Next: ../testServer.cpp:672: warning: converting to 'int' from 'double' Dirk Zimoch
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
