Hi Mark
So, all the embedded processor has to do is to transfer the raw 2D data
to a host computer by whatever means necessary, and areaDetector takes
care of the rest. Sounds good, thanks!
/Peter
On 03/28/2012 12:14 PM, Mark Rivers wrote:
Hi Peter,
The EPICS areaDetector module supports an object called an NDArray,
which is an N-dimensional array. EPICS drivers generate these arrays
from the underlying hardware library, and pass them to plugins.
Plugins do things like save the arrays to disk, send the data to
EPICS waveform records, perform statistics calculations on them, and
extract regions-of-interest (ROIs). The ROIs can be any dimensions,
so they can extract single rows, single columns, etc. The ROI plugin
is itself a source of new NDArrays, and plugin chains can be
constructed at run-time.
In your case, if your driver generated NDArrays (N=2) you could do
the following:
Driver -> ROI plugin (extract 1 row or column) -> waveform record
plugin
This processing all happens below the level of EPICS records, so it
is very fast and efficient. Data rates of hundred of megabytes per
second are not a problem.
Although the NDArrays were designed originally to be used in
imaging-type detectors, I have used them for a spectroscopy detector
somewhat similar to yours, where the data contain spectra, not
images.
________________________________________ From:
[email protected] [[email protected]] on
behalf of Peter Milne [[email protected]] Sent: Wednesday, March
28, 2012 4:47 AM To: Tech-talk Subject: Extract a column of data from
2D Waveform Record
The ACQ196 multi-channel digitizer includes an embedded
microprocessor and EPICS IOC, and in normal operation outputs a
Waveform Record per channel on a relaxed schedule, 1Hz typical.
The data from the hardware is a 2D array in [sample][channel] order,
and embedded software takes care of extracting ("channelizing") the
data so that each waveform record is a 1D array eg CH01[sample].
Now we have a requirement to run this at higher pulse rates, up to
60Hz. The embedded software will not be able to channelize the raw
data at this rate, although it should be possible to present a single
Waveform Record per pulse containing the 2D data.
My question is how to handle this 2D record in a client and/or soft
IOC running on another host?.
The client software needs to be able to take a slice [:][ch].
Maybe it's quite easy to do this outside the IOC (eg with Python
Channel access), but ideally it would happen inside an IOC so that
it's completely transparent to a client. The Subarray record is an
obvious choice, but it appears to take a contiguous block of data,
there doesn't seem to be a concept of a stride value.
eg assuming the Waveform Record refers to data [samples][channels]
with dimension (typical) [1024][96], the extract routine needs to run
through the data set with a stride of 96.
It looks like subarray could be used to extract [sample-N][:] but
not the required [:][channel].
Any suggestions welcome.
Thanks
Peter.
-- Peter Milne [email protected] D-TACQ
Solutions Ltd www.d-tacq.com
D-TACQ Solutions Ltd www.d-tacq.com
- Extract a column of data from 2D Waveform Record Peter Milne
- RE: Extract a column of data from 2D Waveform Record Mark Rivers
Re: Proposed support for additional Modbus data types Eric Norum
<2012>
Re: Extract a column of data from 2D Waveform Record Andrew Johnson
<2012>
