1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: menuFtype for 64 bit integers aka. long long and unsigned long long
To: [email protected]
Date: Mon, 26 Mar 2012 09:06:02 -0600
Hi Hinko,
On 2012-03-26 Hinko Kocevar wrote:
> Our instrument natively uses 64-bit integers for some parameter, so I
> reckon that using casted epicsFloat64 back to integer 64 would not cut it.
> Right the only solution I see using two 32-bit integers in an array.
That is probably the best and safest solution, and I'd recommend making them
signed integers (DBF_LONG) not unsigned (DBF_ULONG) so you don't have any
problems with Channel Access which can pretend that DBF_ULONG values are
actually DBF_DOUBLE.  You can use the aSub record to transport and process
those arrays within the IOC, and I think the sequencer will also be able to
handle them properly.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
menuFtype for 64 bit integers aka. long long and unsigned long long Hinko Kocevar
RE: menuFtype for 64 bit integers aka. long long and unsigned long long Mark Rivers
Re: menuFtype for 64 bit integers aka. long long and unsigned long long Hinko Kocevar
Prev: RE: Alarm annunciation via email in CSS BEAST Kasemir, Kay
Next: Google Groups subscription to tech-talk? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: menuFtype for 64 bit integers aka. long long and unsigned long long Hinko Kocevar
Next: waveform ENUM FTVL or BOOL FTVL Hinko Kocevar
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
