> read/write issues, multi-file data processing, etc require the corresponding extra service.
Are you talking about a client/server architecture? An add-on piece of software you have to pay for? Is there a web page (a pointer) that talks about those topics and their implementation? (sample code?) It turns out a good starting point may be http://www.hdfgroup.org/hdf5-quest.html#GENERAL Although you may not have the answer yet, has anyone though (at least conceptually) of a h5 tree structure (database) design for archiving? Would that be time based? (tree node like /date/20120315) Would that be hardware based? (/chassis_id/device_type/device_id) Would that be PV name base? (archiving of AAA:BBB:CCC pv is located at /AAA/BBB/CCC ) Would that be subsystem based? ( /injector/solenoids/I:SO01/current ) the last 3 at once with links? Thanks, -- E
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
