1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: "Size of symbol changed" warnings building EPICS Base 3.14.12.2
Cc: [email protected]
Date: Tue, 20 Mar 2012 17:58:29 +0100
Andrew Johnson wrote:
Hi Dirk,
Interesting, good detective work!
On 2012-03-20 Dirk Zimoch wrote:
In cac.cpp we find:
#define epicsAssertAuthor "Jeff Hill [email protected]"
But in templateInstances.cpp epicsAssertAuthor is not defined.
So does defining it there fix the problem?
- Andrew
It will remove the warning. But is that a fix?
Consider code where epicsAssertAuthor is A where the template is inlined and B where the template is explicitly instantiated. Depending on the Optimization flag, you get different behavior! Here, is it only a message text, but it may be worse.
BEWARE: PHILOSOPHY!
It seems that using macros, including 'assert', in any inline code is simply wrong programming. However, I cannot remember that I have ever seen such a statement in any C++ book. It seems logical when you consider what inline means and what macros are made for. They are simply incompatible. But typically C++ books only say things like: "With C++ inline code, you don't need macros any more. Inline code is much better, type safe, etc than macros." Unfortunately that is a lie. It is hard to get inline code right and you cannot do everything with inline code that you can do with macros.
Of course something like
template <class T>
T max(T a, T b) { return (a < b) ? b : a; }
is better than
#define max(a,b) ( (a) < (b) ? (b) : (a) )
when used in a context like max(getchar(), i++)
But often life is is more complicated than this.
Inline code is better than macros if you are a very experienced and professional C++ programmer. Otherwise you will suffer from the one million pitfalls in C++. And still you cannot do something like 'assert' in C++ inline code.
END PHILOSOPHY.
Maybe this is the wrong part:
#ifndef epicsAssertAuthor
#   define epicsAssertAuthor 0
#endif
In base, only Jeff ever sets epicsAssertAuthor. So we can replace it with a constant :-)
Dirk
"Size of symbol changed" warnings building EPICS Base 3.14.12.2 J. Lewis Muir
Re: "Size of symbol changed" warnings building EPICS Base 3.14.12.2 Dirk Zimoch
Re: "Size of symbol changed" warnings building EPICS Base 3.14.12.2 Andrew Johnson
Prev: Re: 32-bit TIFFs and PIL J. Lewis Muir
Next: RE: 32-bit TIFFs and PIL Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: "Size of symbol changed" warnings building EPICS Base 3.14.12.2 Andrew Johnson
Next: ASYN Communication through windows serial port (via USB) Josh Stein
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
