1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: [ASYN-vxi11] can't connect to Tektronix scope on Fedora 16
To: "'Pavel Masloff'" <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Tue, 20 Mar 2012 14:16:18 +0000
Here’s how to debug this by turning on all asynTrace debugging on that port driver:
vxi11Configure("L0", "172.20.92.3", 0, 0.0, "inst0", 0)
asynSetTraceIOMask(“L0”,0,2)
asynSetTraceMask(“L0”,0,255)
From: [email protected] [mailto:[email protected]] On Behalf Of Pavel Masloff
Sent: Tuesday, March 20, 2012 9:12 AM
To: EPICS Tech Talk
Subject: Re: [ASYN-vxi11] can't connect to Tektronix scope on Fedora 16
UPDATE:
i can talk to the scope more or less. but what do these error messages mean and where do they come from?? I haven't had such on RHEL...
On Tue, Mar 20, 2012 at 5:47 PM, Pavel Masloff <[email protected]> wrote:
Hello all,
The Tektronix TDS3000/5000 support worked perfectly well on Red Hat Linux 5.5.
Now I have decided to run an IOC on Fedora 16 and here's what I have got:
## EPICS R3.14.12.2 $Date: Mon 2011-12-12 14:09:32 -0600$
## EPICS Base built Mar 14 2012
2012/03/20 17:34:57.555 scopeTest:: queueRequest failed
2012/03/20 17:34:57.556 scopeTest:: queueRequest failed
2012/03/20 17:34:58.057 scopeTest:clearMenuBO queueRequest failed port L0 not connected
2012/03/20 17:34:58.057 scopeTest:initBO queueRequest failed port L0 not connected
2012/03/20 17:34:58.057 scopeTest:frontPanelLockBO queueRequest failed port L0 not connected
2012/03/20 17:34:58.057 scopeTest:ethernetNameSI queueRequest failed port L0 not connected
## Start any sequence programs
epics> 2012/03/20 17:34:58.557 scopeTest:scopeBusyBI queueRequest failed port L0 not connected
2012/03/20 17:34:59.057 scopeTest:scopeBusyBI queueRequest failed port L0 not connected
2012/03/20 17:34:59.557 scopeTest:scopeBusyBI queueRequest failed port L0 not connected
2012/03/20 17:35:00.057 scopeTest:scopeBusyBI queueRequest failed port L0 not connected
2012/03/20 17:35:00.557 scopeTest:scopeBusyBI queueRequest failed port L0 not connected
2012/03/20 17:35:01.057 scopeTest:scopeBusyBI queueRequest failed port L0 not connected
2012/03/20 17:35:01.065 L0 vxi11 clientCall errno Success clnt_stat 5
2012/03/20 17:35:01.065 L0 vxiCreateIrqChannel (create_intr_chan): RPC: Timed out
2012/03/20 17:35:01.065 L0 Warning -- SRQ not operational.
I have double-checked it works on RHEL with version of ASYN, BASE, SNC, etc! What can be the problem with Fedora? I am using epics base 3-14-12-2, ASYN 4-18. And connect to the scope via direct Ethernet connection:
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Phone: +7 (812) 461 01 01
Best regards,
Pavel Maslov, MS
Re: [ASYN-vxi11] can't connect to Tektronix scope on Fedora 16 Pavel Masloff
Prev: RE: [ASYN-vxi11] can't connect to Tektronix scope on Fedora 16 Mark Rivers
Next: Support for Xantrex XDC 60-100? Wesley Moore
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: [ASYN-vxi11] can't connect to Tektronix scope on Fedora 16 Pavel Masloff
Next: Re: [ASYN-vxi11] can't connect to Tektronix scope on Fedora 16 Pavel Masloff
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
