The Tektronix TDS3000/5000 support worked perfectly well on Red Hat Linux 5.5. Now I have decided to run an IOC on Fedora 16 and here's what I have got: ############################################################################ ## EPICS R3.14.12.2 $Date: Mon 2011-12-12 14:09:32 -0600$ ## EPICS Base built Mar 14 2012 ############################################################################ 2012/03/20 17:34:57.555 scopeTest:: queueRequest failed 2012/03/20 17:34:57.556 scopeTest:: queueRequest failed 2012/03/20 17:34:58.057 scopeTest:clearMenuBO queueRequest failed port L0 not connected 2012/03/20 17:34:58.057 scopeTest:initBO queueRequest failed port L0 not connected 2012/03/20 17:34:58.057 scopeTest:frontPanelLockBO queueRequest failed port L0 not connected 2012/03/20 17:34:58.057 scopeTest:ethernetNameSI queueRequest failed port L0 not connected iocRun: All initialization complete ## Start any sequence programs epics> 2012/03/20 17:34:58.557 scopeTest:scopeBusyBI queueRequest failed port L0 not connected 2012/03/20 17:34:59.057 scopeTest:scopeBusyBI queueRequest failed port L0 not connected 2012/03/20 17:34:59.557 scopeTest:scopeBusyBI queueRequest failed port L0 not connected 2012/03/20 17:35:00.057 scopeTest:scopeBusyBI queueRequest failed port L0 not connected 2012/03/20 17:35:00.557 scopeTest:scopeBusyBI queueRequest failed port L0 not connected 2012/03/20 17:35:01.057 scopeTest:scopeBusyBI queueRequest failed port L0 not connected 2012/03/20 17:35:01.065 L0 vxi11 clientCall errno Success clnt_stat 5 2012/03/20 17:35:01.065 L0 vxiCreateIrqChannel (create_intr_chan): RPC: Timed out 2012/03/20 17:35:01.065 L0 Warning -- SRQ not operational. ############################################################################ I have double-checked it works on RHEL with version of ASYN, BASE, SNC, etc! What can be the problem with Fedora? I am using epics base 3-14-12-2, ASYN 4-18. And connect to the scope via direct Ethernet connection: vxi11Configure("L0", "172.20.92.3", 0, 0.0, "inst0", 0) -- Best regards, Pavel Maslov, MS Controls Engineer at Pulsed power Lab Efremov Institute for Electro-Physical Apparatus St. Petersburg, Russia Mobile: +7 (951) 672 22 19 Phone: +7 (812) 461 01 01
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
