Hi Tim (and tech-talkers),
I know you've done quite a bit with TIFF files, so I've got a question for you.
The areaDetector NDFileTIFF plugin can write 8-bit, 16-bit and 32-bit TIFF files. All of them can be read fine by ImageJ and IDL. However, the 32-bit TIFFs cannot be read by the Python Imaging Library (PIL). But 32-bit TIFF files written by the Dectris Pilatus driver can be read by PIL.
Do you have any idea what needs to be done to make a 32-bit TIFF readable by PIL?
From: [email protected] [[email protected]] on behalf of Matt Newville [[email protected]]
Sent: Monday, March 19, 2012 10:34 PM
To: Mark Rivers
Cc: Ross Harder; [email protected]
Subject: Re: tiffs
Hi Mark,
Oh, right, I was using tiffinfo on my Mac, after moving the files over
(so that the display was faster). tiffinfo -v says 3.9.4 I
installed libtiff-tools on corvette, so tiffinfo (3.9.5) now works
there too.
---Matt
On Mon, Mar 19, 2012 at 10:19 PM, Mark Rivers <[email protected]> wrote:
> Hi Matt,
> Thanks for that information.
> What version of tiffinfo are you running? Your output format is slightly different from what I get on idea and millenia. I'd like to run tiffinfo on a Pilatus file and on the areaDetector file and see how they differ. Then maybe I can change areaDetector's writer slightly to produce files that PIL can read.
> Mark
> Sent: Monday, March 19, 2012 9:54 PM
> To: Mark Rivers
> Subject: Re: tiffs
> Hi Mark, Ross, David,
> On Mon, Mar 19, 2012 at 5:46 PM, Mark Rivers <[email protected]> wrote:
>> Ross,
>> I just talked to Matt Newville. He thought that maybe this was a problem with an older version of PIL. However, I just tried it on our new Linux system (corvette) and I can read 8-bit and 16-bit TIFFs fine in PIL, but 32-bit does not work.
>> I used the simDetector to create 8-bit, 16-bit and 32-bit integer TIFF files.
>> I then read them in IDL. It worked fine.
>> IDL> t = read_tiff('8bit_int_1.tiff')
>> IDL> help, t
>> T BYTE = Array[1024, 1024]
>> IDL> t = read_tiff('16bit_int_1.tiff')
>> IDL> help, t
>> T UINT = Array[1024, 1024]
>> IDL> t = read_tiff('32bit_int_1.tiff')
>> IDL> help, t
>> T ULONG = Array[1024, 1024]
>> I then tried to read them in PIL. 8-bit and 16-bit worked, but not 32-bit.
>> corvette:~/scratch>python
>> Python 2.7.1 (r271:86832, Apr 12 2011, 16:15:16)
>> [GCC 4.6.0 20110331 (Red Hat 4.6.0-2)] on linux2
>> Type "help", "copyright", "credits" or "license" for more information.
>> Imported history from: '/home/epics/.pyhist'
>>>>> from PIL import Image
>>>>> im = Image.open("8bit_int_1.tiff")
>>>>> im.show()
>>>>> im = Image.open("16bit_int_1.tiff")
>>>>> im.show()
>>>>> im = Image.open("32bit_int_1.tiff")
>> Traceback (most recent call last):
>> File "<stdin>", line 1, in <module>
>> File "/usr/lib64/python2.7/site-packages/PIL/Image.py", line 1980, in open
>> raise IOError("cannot identify image file")
>> IOError: cannot identify image file
>> Matt, is the version of PIL I am running on corvette with Python 2.7.1 a recent version? Do you understand why I can't read 32-bit TIFFs?
>> Mark
>> -----Original Message-----
>> From: Mark Rivers
>> Sent: Monday, March 19, 2012 2:59 PM
>> To: 'Ross Harder'; '[email protected]'
>> Subject: RE: tiffs
>> Hi Ross,
>> I just ran the Linux utility "tiffinfo" on your file:
>> idea:~>tiffinfo /corvette/home/epics/scratch/im.tiff
>> TIFF Directory at offset 0x3fe00c (4186124)
>> Image Width: 1023 Image Length: 1023
>> Bits/Sample: 32
>> Compression Scheme: None
>> Photometric Interpretation: min-is-black
>> Samples/Pixel: 1
>> Rows/Strip: 1023
>> Planar Configuration: single image plane
>> Make: Unknown
>> Model: Unknown
>> It also says that the image directory is near the end of the file. But it is clearly a valid TIFF file, so why doesn't PIL like it?
>> Mark
>> From: Mark Rivers
>> Sent: Monday, March 19, 2012 2:55 PM
>> To: 'Ross Harder'; [email protected]
>> Subject: RE: tiffs
>> Hi Ross,
>> It is not the "first image" that is near the end of the file, it is the "first image directory". It looks like the image directory is being placed after the image.
>> If you look at the NDFileTIFF plugin, you will see that it is very simple. It uses libtiff. For a 32-bit mono image these are the only calls to libtiff in the plugin, and they are done in this order:
>> TIFFOpen(fileName, "w")
>> TIFFSetField(this->output, TIFFTAG_BITSPERSAMPLE, bitsPerSample);
>> TIFFSetField(this->output, TIFFTAG_SAMPLESPERPIXEL, samplesPerPixel);
>> TIFFSetField(this->output, TIFFTAG_PHOTOMETRIC, photoMetric);
>> TIFFSetField(this->output, TIFFTAG_PLANARCONFIG, planarConfig);
>> TIFFSetField(this->output, TIFFTAG_IMAGEWIDTH, sizeX);
>> TIFFSetField(this->output, TIFFTAG_IMAGELENGTH, sizeY);
>> TIFFSetField(this->output, TIFFTAG_ROWSPERSTRIP, rowsPerStrip);
>> TIFFSetField(this->output, TIFFTAG_MAKE, ManufacturerString);
>> TIFFSetField(this->output, TIFFTAG_MODEL, ModelString);
>> stripSize = TIFFStripSize(this->output);
>> TIFFGetField(this->output, TIFFTAG_IMAGELENGTH, &sizeY);
>> nwrite = TIFFWriteEncodedStrip(this->output, 0, pArray->pData, stripSize);
>> TIFFClose(this->output);
>> So if the directory is being put at the end of the file, it must be because that's how libtiff does it.
>> Mark
>> From: [email protected] [mailto:[email protected]] On Behalf Of Ross Harder
>> Sent: Monday, March 19, 2012 2:40 PM
>> To: Mark Rivers; [email protected]
>> Subject: tiffs
>> Hi Mark,
>> I've placed a tiff from a recent scan on the xor ftp server. I've
>> also included a short python program that interrogates the file.
>> I don't understand why the offset to the first image is almost at the
>> end of the file?
>> http://ftp.xor.aps.anl.gov/sector33_34/34idc/tifread/
>> In [121]: run tiffinfo.py
>> Little endian is II: II
>> Sanity check for endianess should be 42 if a valid tif: (42,)
>> Offset of first image file directory in the tif: (4186124,)
>> Any thoughts?
>> Ross
> Sorry for the trouble. I do remember that 32-bit images from a Pilatus
> could not be read with older versions of PIL, but can be read now
> (taking a random one from Nov 2011):
> ~> tiffinfo Pilatus_Nov2011.tif
> Pilatus_Nov2011.tif: Warning, incorrect count for field "DateTime"
> (32, expecting 20); tag trimmed.
> TIFFReadDirectory: Warning, Pilatus_Nov2011.tif: invalid TIFF
> directory; tags are not sorted in ascending order.
> TIFFReadDirectory: Warning, Pilatus_Nov2011.tif: unknown field with
> tag 36864 (0x9000) encountered.
> tag 36865 (0x9001) encountered.
> tag 36866 (0x9002) encountered.
> tag 36867 (0x9003) encountered.
> tag 36868 (0x9004) encountered.
> tag 36870 (0x9006) encountered.
> tag 36876 (0x900c) encountered.
> tag 36877 (0x900d) encountered.
> tag 36878 (0x900e) encountered.
> tag 36879 (0x900f) encountered.
> tag 36880 (0x9010) encountered.
> tag 37120 (0x9100) encountered.
> Pilatus_Nov2011.tif: Warning, incorrect count for field "Tag 36864"
> (0, expecting 1); tag ignored.
> Pilatus_Nov2011.tif: Warning, incorrect count for field "Tag 36870"
> TIFF Directory at offset 0x82 (130)
> Subfile Type: (0 = 0x0)
> Image Width: 487 Image Length: 195
> Resolution: 69.5714, 69.5714
> Bits/Sample: 32
> Sample Format: signed integer
> Rows/Strip: 195
> ImageDescription: # Pixel_size 172e-6 m x 172e-6 m
> # Silicon sensor, thickness 0.000320 m
> # Exposure_time 16.700000 s
> # Exposure_period 16.700000 s
> # Tau = 203.0e-09 s
> For this tiff file
>>>> import Image
>>>> Image.open('Pilatus_Nov2011.tif').show()
> displays fine. That sure looks like a 32-bit integer TIFF to me,
> though tiffinfo wasn't all that happy with some of the tags.
> But I see exactly the same behavior for the tiff files that Mark
> created with simDetector, that Image.open() complains about not being
> able to identify the image file. I'm not sure why that is.... The
> PIL docs are pretty opaque, but I believe this works:
>>>> data = open('32bit_int_1.tiff').read() # raw file read
>>>> img = Image.frombuffer('I', (1024, 1024), data, 'raw', 'I')
>>>> img.show()
> This shows one small bright spot in upper left, around pixel 200,100,
> with a max intensity of 186. It's definitely lame that Image.open()
> doesn't auto-recognize this file! I don't understand why it
> understood the Pilatus file, but not this one (all the
> Image.frombuffer() call is doing is datatype as an integer, and
> explicitly setting the size).
> BTW, to convert this to a numpy array, use
>>>> np_data = numpy.array(img.getdata(), dtype='int32').reshape(1024, 1024).transpose()
> Finally, if you're interested, I have a start of an Image Display GUI
> (wxPython) for Epics Area Detectors. This uses exactly this
> 'Image.frombuffer()' method to convert data directly from an
> AreaDetector PV data. Not much documentation yet, but code is at at
> https://github.com/pyepics/epicsapps/tree/master/AreaDetector_Display
> and a screenshot is at
> http://pyepics.github.com/epicsapps/ad_display.html
> I've also made a Windows EXE made from this, but haven't posted it online yet.
> Hope that helps,
> --Matt Newville <newville at cars.uchicago.edu> 630-252-0431
- Re: 32-bit TIFFs and PIL Matt Newville
- Re: 32-bit TIFFs and PIL J. Lewis Muir
BOY: Macro for workspace directory? Ralph Lange
[ASYN-vxi11] can't connect to Tektronix scope on Fedora 16 Pavel Masloff
<2012>
RE: Macro for workspace directory? Chen, Xihui
<2012>
