1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Build problem with db dependencies
Date: Tue, 20 Mar 2012 08:47:29 +0100
You can also try creating the dependencies correctly, e.g. by putting
$(COMMON_DIR)/%.db$(RAW)$(DEP): %.substitutions
        @$(RM) $@
        $(PERL) -e 'undef $$/; $$_=<>;
@d=m/(?:^|})\s*file\s+\"?([^\"{\s]*)\s*\{/mg; print
"$(COMMON_DIR)/$*.db$(RAW): @d\n";' $< > [email protected]
        $(MV) [email protected] $@
or something functionally equivalent into your RULES file.
Amazing how perl turns everything into an obvious one-liner, isn't it?
Cheers,
~Ralph
On Tue Mar 20 2012 07:00:45 GMT+0100 (CET), Emma Shepherd
<[email protected]> wrote:
> Hi Bruce,
> Good timing - I just ran into the same problem today!  I agree, it's a pain to have to run 'make rebuild' every time.  Thanks for the patch, that works for me too.
> Cheers,
> Emma
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf Of Bruce Hill
> Sent: Saturday, 18 February 2012 11:31 AM
> To: [email protected]
> Subject: Build problem with db dependencies
> Has anyone else run into a build dependency problem with base-3,14,12?
> What I've been finding is that I can build an IOC or module that depends on
> *.db or *.template files from another module successfully the first time, but
> it fails on subsequent builds.
> Example build output:
> % make
> perl /reg/g/pcds/package/epics/3.14/base/R3.14.12-0.4.0/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
> perl /reg/g/pcds/package/epics/3.14/base/R3.14.12-0.4.0/bin/linux-x86_64/makeMakefile.pl O.RTEMS-beatnik ../../..
> perl /reg/g/pcds/package/epics/3.14/base/R3.14.12-0.4.0/bin/linux-x86_64/makeMakefile.pl O.linux-x86 ../../..
> mkdir O.Common
> /usr/bin/make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install
> make[1]: Entering directory `/reg/neh/home/bhill/wa2/epics/iocTest/test-R3.14.12/evr1/myEvrApp/Db/O.linux-x86_64'
> perl /reg/g/pcds/package/epics/3.14/base/R3.14.12-0.4.0/bin/linux-x86_64/makeDbDepends.pl ../O.Common/iocAdmin.db ../iocAdmin.substitutions >> iocAdmin.db.d
> echo "../O.Common/iocAdmin.db : " >> iocAdmin.db.d
> Inflating database from ../iocAdmin.substitutions
> /reg/g/pcds/package/epics/3.14/extensions/current/bin/linux-x86/msi   -I. -I.. -I../O.Common -I ../../../db     -I/reg/g/pcds/package/epics/3.14/base/R3.14.12-0.4.0/db     -I/reg/g/pcds/package/epics/3.14/modules/autosave/R4.2.1.2-2.7.0/db -I/reg/g/pcds/package/epics/3.14/modules/iocAdmin/R3.0.0-1.6.0/db -I/reg/neh/home/bhill/wa2/trunk/pcds/epics/modules/event/current/db  -S../iocAdmin.substitutions > iocAdmin.tmp
> mv iocAdmin.tmp ../O.Common/iocAdmin.db
> perl /reg/g/pcds/package/epics/3.14/base/R3.14.12-0.4.0/bin/linux-x86_64/makeDbDepends.pl ../O.Common/evr.db ../evr.substitutions >> evr.db.d
> echo "../O.Common/evr.db : " >> evr.db.d
> Inflating database from ../evr.substitutions
> /reg/g/pcds/package/epics/3.14/extensions/current/bin/linux-x86/msi   -I. -I.. -I../O.Common -I ../../../db     -I/reg/g/pcds/package/epics/3.14/base/R3.14.12-0.4.0/db     -I/reg/g/pcds/package/epics/3.14/modules/autosave/R4.2.1.2-2.7.0/db -I/reg/g/pcds/package/epics/3.14/modules/iocAdmin/R3.0.0-1.6.0/db -I/reg/neh/home/bhill/wa2/trunk/pcds/epics/modules/event/current/db  -S../evr.substitutions > evr.tmp
> mv evr.tmp ../O.Common/evr.db
> Installing created db file ../../../db/iocAdmin.db
> Installing created db file ../../../db/evr.db
> make[1]: Leaving directory `/reg/neh/home/bhill/wa2/epics/iocTest/test-R3.14.12/evr1/myEvrApp/Db/O.linux-x86_64'
> /usr/bin/make -C O.RTEMS-beatnik -f ../Makefile TOP=../../.. T_A=RTEMS-beatnik install
> make[1]: Entering directory `/reg/neh/home/bhill/wa2/epics/iocTest/test-R3.14.12/evr1/myEvrApp/Db/O.RTEMS-beatnik'
> make[1]: Nothing to be done for `install'.
> make[1]: Leaving directory `/reg/neh/home/bhill/wa2/epics/iocTest/test-R3.14.12/evr1/myEvrApp/Db/O.RTEMS-beatnik'
> /usr/bin/make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install
> make[1]: Entering directory `/reg/neh/home/bhill/wa2/epics/iocTest/test-R3.14.12/evr1/myEvrApp/Db/O.linux-x86'
> make[1]: Leaving directory `/reg/neh/home/bhill/wa2/epics/iocTest/test-R3.14.12/evr1/myEvrApp/Db/O.linux-x86'
> (232) 04:29 PM psusr115:~/wa2/epics/iocTest/test-R3.14.12/evr1/myEvrApp/Db
> % make
> make[1]: *** No rule to make target `ioc.db', needed by `../O.Common/iocAdmin.db'.  Stop.
> make: *** [install.linux-x86_64] Error 2
> The first build succeeds because RELEASE_DBFLAGS has a list of -I directives
> which includes the released iocAdmin module's db dir, so msi is able to use that
> to successfully build my iocAdmin.db file.
> The problem arises because the first build also creates a dependency file
> for iocAdmin.db using makeDbDepends.pl that looks like this.
> % cat O.linux-x86_64/iocAdmin.db.d
> ../O.Common/iocAdmin.db: ioc.db access.db iocCluster.db
> Subsequent builds fail because ioc.db is over in the released iocAdmin  module's db dir,
> which doesn't end up on the vpath for .db files.
> I think I have a fix for it, but I can't figure out why this hasn't been a problem for us
> and others before now.
> I'd like to avoid customizing my base configure files to the extent possible,
> but these changes seem to fix the problem.
> % svn diff
> Index: CONFIG_APP_INCLUDE
> --- CONFIG_APP_INCLUDE  (revision 8621)
> +++ CONFIG_APP_INCLUDE  (working copy)
> @@ -16,6 +16,8 @@
>     RELEASE_INCLUDES += $$(addprefix -I,$$(wildcard $$(strip $$($(1)))/include))
>     RELEASE_DBDFLAGS += $$(addprefix -I,$$(wildcard $$(strip $$($(1)))/dbd))
>     RELEASE_DBFLAGS += $$(addprefix -I,$$(wildcard $$(strip $$($(1)))/db))
> +  RELEASE_DIRS_DBD += $$(wildcard $$(strip $$($(1)))/dbd)
> +  RELEASE_DIRS_DB  += $$(wildcard $$(strip $$($(1)))/db)
>     RELEASE_PERL_MODULE_DIRS += $$(wildcard $$($(1)_LIB)/perl)
>   endef
>   $(foreach top, $(RELEASE_TOPS), $(eval $(call RELEASE_FLAGS_template,$(top)) ))
> Index: RULES.Db
> --- RULES.Db    (revision 8757)
> +++ RULES.Db    (working copy)
> @@ -11,10 +11,10 @@
>   #####################################################  vpath
>   vpath %.dbd $(USR_VPATH) $(GENERIC_SRC_DIRS) $(dir $(DBD))
> -vpath %.db $(USR_VPATH) $(GENERIC_SRC_DIRS) $(dir $(DB))
> -vpath %.vdb $(USR_VPATH) $(GENERIC_SRC_DIRS) $(dir $(DB))
> +vpath %.db $(USR_VPATH) $(GENERIC_SRC_DIRS) $(dir $(DB)) $(RELEASE_DIRS_DB)
> +vpath %.vdb $(USR_VPATH) $(GENERIC_SRC_DIRS) $(dir $(DB)) $(RELEASE_DIRS_DBD)
>   vpath %.substitutions $(USR_VPATH) $(GENERIC_SRC_DIRS) $(COMMON_DIR)
> -vpath %.template $(USR_VPATH) $(GENERIC_SRC_DIRS) $(COMMON_DIR)
> +vpath %.template $(USR_VPATH) $(GENERIC_SRC_DIRS) $(COMMON_DIR) $(RELEASE_DIRS_DB)
>   vpath bpt%.data $(USR_VPATH) $(GENERIC_SRC_DIRS) $(COMMON_DIR)
>   vpath %.acf $(USR_VPATH) $(GENERIC_SRC_DIRS) $(COMMON_DIR)
>   vpath %.acs $(USR_VPATH) $(GENERIC_SRC_DIRS) $(COMMON_DIR)
> Any comments would be appreciated.
> Thanks,
> - Bruce
> <br>This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you.
Re: Build problem with db dependencies Ralph Lange
RE: Build problem with db dependencies Gougnaud Françoise
Build problem with db dependencies Bruce Hill
RE: Build problem with db dependencies Emma Shepherd
Prev: ARM - EPICS performance evaluation ssahoo
Next: Re: Build problem with db dependencies Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Build problem with db dependencies Emma Shepherd
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
