1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: ARM - EPICS performance evaluation
To: Emmanuel Mayssat <[email protected]>, Peter Jemian <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 19 Mar 2012 10:37:02 -0700 (PDT)
The link I initially sent is referring to the arduino. Not the ts7370...
Unless you are talking about another link.
Also, ARM OS are not real time.
That means you can have latency between successive samples. (that's another issue, not discussed so far)
I believe there is a way to use hardware interrupt.
The 4ms is observed at the epics layer (asyn driver + display on a remote OPI)
I probably tested it at the OS level (simple C loop program), but I can't remember, that was some time ago.
The ADC is not in the CPU and the ARM clock (200MHz for this model) is misleading and irrelevant.
I didn't come up with that number though, one of my electronic coworker did.
I can just ascertain that IOs are issues for ARM platforms.
Since there are several of you working on ts7xxx ARM (based on the few emails I received),
maybe someone can back up that claim. I am probably wrong ;-)
E
To: Peter Jemian <[email protected]>; "[email protected]" <[email protected]>
Sent: Monday, March 19, 2012 10:00 AM
Pete,
What is that link?
E
To: [email protected]
Cc: [email protected]
Sent: Saturday, March 17, 2012 8:03 AM
Follow that google.com link and you will see the context of the 4 ms interval.  The article shows how it can go faster.
Pete
Re: ARM - EPICS performance evaluation Peter Jemian
Re: ARM - EPICS performance evaluation Emmanuel Mayssat
Prev: Re: ARM - EPICS performance evaluation Pete R. Jemian
Next: RE: Build problem with db dependencies Emma Shepherd
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: ARM - EPICS performance evaluation ssahoo
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
