g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: RE: ARM - EPICS performance evaluation
To: "ssahoo@vecc.gov.in" <ssahoo@vecc.gov.in>, "tech-talk@aps.anl.gov" <tech-talk@aps.anl.gov>
Date: Mon, 19 Mar 2012 15:10:26 +0000
Ø  What is meant by free channel test and pend event test?
The pend event measures the time to call ca_pend_event(1e-9) and the free channel test measures the time to call ca_clear_channel.
Jeff
From: tech-talk-bounces@aps.anl.gov [mailto:tech-talk-bounces@aps.anl.gov] On Behalf Of ssahoo@vecc.gov.in
Sent: Saturday, March 17, 2012 9:58 AM
To: tech-talk@aps.anl.gov
Subject: Re: ARM - EPICS performance evaluation
 I am using the TS7500 (ARM 9) board. By performance evaluation i meant the network and latency performance measurement. I have used the catime tool in EPICs for the client/server network performance (i.e channel access).But the results that i am getting with this board when compared to a linux-x86 system (intel i3 processor) are very poor. I am attaching the two reports generated. Have u performed such measurement for your boards. It would be great if u could suggest something regarding this or how to perform the performance measurements.
ARM 9 Board :
Testing with 10000 channels named VEC:Start
Channel Connect Test
Per Op, 980.5962 uS (   0.0010 MHz ),   0.5221 snd Mbps,   0.2611 rcv Mbps
Search tries per chan - mean = 1.0 std dev = 0.1 min = 1.0 max = 2.0
channel name=VEC:Start, native type=5, native count=1
Pend Event Test
Per Op,   2.9166 uS (   0.3429 MHz )
DBR_FLOAT Test
       ### async put test ###
Per Op, 162.5500 uS (   0.0062 MHz ),   1.1812 snd Mbps,   0.0000 rcv Mbps
       ### async get test ###
Per Op, 193.4481 uS (   0.0052 MHz ),   0.6617 snd Mbps,   0.9925 rcv Mbps
       ### synch get test ###
Per Op, 5874.1800 uS (   0.0002 MHz ),   0.0218 snd Mbps,   0.0327 rcv Mbps
DBR_DOUBLE Test
Per Op, 171.7263 uS (   0.0058 MHz ),   1.1181 snd Mbps,   0.0000 rcv Mbps
Per Op, 188.0780 uS (   0.0053 MHz ),   0.6806 snd Mbps,   1.0209 rcv Mbps
Per Op, 5855.1620 uS (   0.0002 MHz ),   0.0219 snd Mbps,   0.0328 rcv Mbps
DBR_STRING Test
Per Op, 121.9442 uS (   0.0082 MHz ),   3.6738 snd Mbps,   0.0000 rcv Mbps
Per Op, 122.7867 uS (   0.0081 MHz ),   1.0425 snd Mbps,   3.6486 rcv Mbps
Per Op, 10904.0876 uS (   0.0001 MHz ),   0.0117 snd Mbps,   0.0411 rcv Mbps
DBR_INT Test
Per Op, 100.5193 uS (   0.0099 MHz ),   1.9101 snd Mbps,   0.0000 rcv Mbps
Per Op, 124.0433 uS (   0.0081 MHz ),   1.0319 snd Mbps,   1.5478 rcv Mbps
Per Op, 5841.4275 uS (   0.0002 MHz ),   0.0219 snd Mbps,   0.0329 rcv Mbps
Get Latency Test
Get Latency - mean = 6060.9 uS, std dev = 24137.5 uS, min = 2256.0 uS max = 176482.1 uS
Free Channel Test
Per Op,   0.4478 uS (   2.2330 MHz ),   0.0000 snd Mbps,   0.0000 rcv Mbps
x86 system:
Per Op,  12.3947 uS (   0.0807 MHz ),  41.3081 snd Mbps,  20.6540 rcv Mbps
Search tries per chan - mean = 1.1 std dev = 0.2 min = 1.0 max = 2.0
Pend Event Test
Per Op,   2.5694 uS (   0.3892 MHz )
DBR_FLOAT Test
Per Op,   0.8990 uS (   1.1123 MHz ), 213.5624 snd Mbps,   0.0000 rcv Mbps
Per Op,   1.1567 uS (   0.8645 MHz ), 110.6575 snd Mbps, 165.9863 rcv Mbps
Per Op, 223.9892 uS (   0.0045 MHz ),   0.5715 snd Mbps,   0.8572 rcv Mbps
DBR_DOUBLE Test
Per Op,   0.6781 uS (   1.4746 MHz ), 283.1310 snd Mbps,   0.0000 rcv Mbps
Per Op,   1.0460 uS (   0.9560 MHz ), 122.3730 snd Mbps, 183.5595 rcv Mbps
Per Op, 235.0035 uS (   0.0043 MHz ),   0.5447 snd Mbps,   0.8170 rcv Mbps
DBR_STRING Test
Per Op,   0.9966 uS (   1.0034 MHz ), 449.5136 snd Mbps,   0.0000 rcv Mbps
Per Op,   1.0918 uS (   0.9159 MHz ), 117.2383 snd Mbps, 410.3341 rcv Mbps
Per Op, 284.6693 uS (   0.0035 MHz ),   0.4496 snd Mbps,   1.5738 rcv Mbps
DBR_INT Test
Per Op,   0.6753 uS (   1.4809 MHz ), 284.3340 snd Mbps,   0.0000 rcv Mbps
Per Op,   1.0411 uS (   0.9606 MHz ), 122.9506 snd Mbps, 184.4258 rcv Mbps
Per Op, 244.8803 uS (   0.0041 MHz ),   0.5227 snd Mbps,   0.7841 rcv Mbps
Get Latency Test
Get Latency - mean = 214.1 uS, std dev = 51.4 uS, min = 164.8 uS max = 3700.0 uS
Free Channel Test
Per Op,   0.4586 uS (   2.1806 MHz ),   0.0000 snd Mbps,   0.0000 rcv Mbps
Shantonu sahoo.
Date: 03/17/2012 05:44AM
Cc: epics <tech-talk@aps.anl.gov>
Well, I am not sure what you call performance evaluation.
But as far as running epics/seq/etc, that's no problem.
(I used 3.14.11 with minimal patching)
The issue you may be facing is I/O access.
On the ts7370 (ARM9), it takes me 4ms to get a AI reading.
The main issues on this board is
1/ no buffering
2/ you are running a full blown linux OS
For higher througput, I am looking at microcontrollers (arduino megas or more advanced)
Read this to get a flavor of the issues ;)
To have a full blown arm production deployment (as we are strongly considering),
there are practical issues:
1/ management of SD images (SD card)
2/ controlled upgrade/change of SD image
To bypass those issues, we are going in the direction of
beagleboard-xm (full blown linux desktop environment, with epics IOC but no direct critical I/O)
attached to microcontrollers (for critical I/O)
Cost of parts ~ $200
One of my coworkers called this design 'smart chassis': with the spare IO, you can monitor the environment (temp, vibration, etc)
I call it 'epics plug-and-play': You plug your chassis to your network and the epics PV are immediately available.
For maintenance, when the hardware is swapped/changed, the ioc software is changed with it.
For troubleshooting on the bench, engineers/technicians can attach a keyboard and a monitor to a chassis and immediately start working. (Qt works great with embedded systems ;)
We design a lot of our electronics, so by using open hardware solutions, we can *in theory* integrate the ARM+ucontroller directly in our electronics design (maybe at 2nd generation design)
...etc...
In short, they are several advantages to this design which fit *OUR* needs.
Looking forward ARM cpu are becoming more and more powerful, epics/qt is on the way...
You see, the tide is also going that direction...
To: Emmanuel Mayssat <emayssat@yahoo.com>
Sent: Friday, March 16, 2012 9:39 AM
Subject: Re: EPICS performance evaluation
Yes, I am using TS7500 from embeddedarm (ARM9)..
So, have u performed any performance evaluation test for ur arm platform.
Thanking you,
ARM - EPICS performance evaluation ssahoo
Re: ARM - EPICS performance evaluation ssahoo
Prev: Re: catime tool Ralph Lange
Next: Re: ARM - EPICS performance evaluation Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Prev: Re: ARM - EPICS performance evaluation ssahoo
Next: ARM - EPICS performance evaluation ssahoo
ANJ, 27 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
