1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: ARM - EPICS performance evaluation
To: [email protected]
Cc: [email protected]
Date: Sat, 17 Mar 2012 10:03:15 -0500 (CDT)
Follow that google.com link and you will see the context of the 4 ms interval.  The article shows how it can go faster.
Pete
----- Reply message -----
Date: Sat, Mar 17, 2012 9:25 am
Subject: ARM - EPICS performance evaluation
To: "Emmanuel Mayssat" <[email protected]>
Cc: "epics" <[email protected]>
4ms for one AI reading seem completely unreasonable. Are you sure?
Emmanuel Mayssat wrote:
> Well, I am not sure what you call performance evaluation.
> But as far as running epics/seq/etc, that's no problem.
> (I used 3.14.11 with minimal patching)
> The issue you may be facing is I/O access.
> On the ts7370 (ARM9), it takes me 4ms to get a AI reading.
> The main issues on this board is
> 1/ no buffering
> 2/ you are running a full blown linux OS
> For higher througput, I am looking at microcontrollers (arduino megas
> or more advanced)
> Read this to get a flavor of the issues ;)
> http://sites.google.com/site/measuringstuff/the-arduino
> To have a full blown arm production deployment (as we are strongly
> considering),
> there are practical issues:
> 1/ management of SD images (SD card)
> 2/ controlled upgrade/change of SD image
> To bypass those issues, we are going in the direction of
> beagleboard-xm (full blown linux desktop environment, with epics IOC
> but no direct critical I/O)
> attached to microcontrollers (for critical I/O)
> Cost of parts ~ $200
> One of my coworkers called this design 'smart chassis': with the spare
> IO, you can monitor the environment (temp, vibration, etc)
> I call it 'epics plug-and-play': You plug your chassis to your network
> and the epics PV are immediately available.
> For maintenance, when the hardware is swapped/changed, the ioc
> software is changed with it.
> For troubleshooting on the bench, engineers/technicians can attach a
> keyboard and a monitor to a chassis and immediately start working. (Qt
> works great with embedded systems ;)
> We design a lot of our electronics, so by using open hardware
> solutions, we can *in theory* integrate the ARM+ucontroller directly
> in our electronics design (maybe at 2nd generation design)
> ...etc...
> In short, they are several advantages to this design which fit *OUR*
> needs.
> Looking forward ARM cpu are becoming more and more powerful, epics/qt
> is on the way...
> You see, the tide is also going that direction...
> *From:* "[email protected]" <[email protected]>
> *To:* Emmanuel Mayssat <[email protected]>
> *Sent:* Friday, March 16, 2012 9:39 AM
> *Subject:* Re: EPICS performance evaluation
> Yes, I am using TS7500 from embeddedarm (ARM9)..
> So, have u performed any performance evaluation test for ur arm platform.
> Thanking you,
Re: ARM - EPICS performance evaluation Emmanuel Mayssat
Prev: Re: ARM - EPICS performance evaluation John William Sinclair
Next: Re: ARM - EPICS performance evaluation ssahoo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RTEMS RPCIO errors Bruce Hill
Next: Re: ARM - EPICS performance evaluation Emmanuel Mayssat
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
