Eric Norum wrote:
For I/O redirection to work a source file must include epicsStdioRedirect.h.
This sucks.
It this is the case, I would say that there is something wrong with the
EPICS redirection. Code should not need to know about its "environment".
This contradicts any good programming practice.
Dirk
It's likely that lots of support modules and drivers have not yet done so.
On Mar 13, 2012, at 2:11 PM, Allison, Stephanie wrote:
Hello,
When using redirection of output to a file in iocshCmd where the command is one that calls report functions via function pointer like dbior:
iocshCmd("dbior > /dat/dbiorOutput")
the output file contains only the output (printf) from the dbior routine itself but not output (printf) from each driver (called using a function pointer in drvet).
Is this a limitation of the iocsh, mixing C and C++, or the non-thread-safeness (as advertised in the app dev guide) of iocshCmd? Or am I doing something else wrong? It happens on linux-x86_64, RTEMS 4.9.4, and vxWorks 5.4.
Thank you,
Stephanie Allison
- Re: iocshCmd, redirection, and function pointers Eric Norum
- iocshCmd, redirection, and function pointers Allison, Stephanie
sysBusToLocalAdrs question Bai Jiaoni
Re: "Size of symbol changed" warnings building EPICS Base 3.14.12.2 Dirk Zimoch
<2012>
RE: iocshCmd, redirection, and function pointers Mark Rivers
<2012>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
