Andrew, Lewis,
If the C++ template instantiation is the problem, then the
-fno-implicit-templates command line option may help. If that is used,
the compiler will not create any code "behind the scenes".
Instead it requires that for each template, you explicitly specify in
which file you want to have the implementation. See section "Where's the
Template?" in the gcc info pages.
In exactly one source code file one has to write a line like
template class epicsSingleton<localHostName>::reference;
Dirk
Andrew Johnson wrote:
Hi Dirk,
On 3/7/12 2:50 AM, Dirk Zimoch wrote:
These two functions,
epicsSingleton<localHostName>::reference::~reference(void) and
epicsSingleton<localHostName>::reference::operator->(void) both
contain 'assert' (see src/libCom/cxxTemplates/epicsSingleton.h).
'assert' is a macro:
# define assert(exp) ((exp) ? (void)0 : \
epicsAssert(__FILE__, __LINE__, #exp, epicsAssertAuthor))
Depending on the optimization level, '(void)0' may be eliminated
and the code becomes shorter (by 4 bytes = 1 PPC instruction).
Try to 'make clean' in the epics base top directory and compile
again.
The problem is more subtle than that, although I suspect that different
optimization levels is probably the underlying cause.
Remember Lewis is using a very old version of g++, from back when C++
templates were new; my guess is that ldppc is recompiling the template
instances it needs to link the code behind the scenes, but it wasn't told the
optimization level that g++ppc used to compile the instances that appear in
the .o files it's linking with so it doesn't get the same length code and
generates that warning. There may be a flag we could turn on to show more
about what's going on inside ldppc, but it's really not worth looking into
IMHO; better to spend the time upgrading to vxWorks 5.5.
- Andrew
- Re: "Size of symbol changed" warnings building EPICS Base 3.14.12.2 J. Lewis Muir
- "Size of symbol changed" warnings building EPICS Base 3.14.12.2 J. Lewis Muir
- Re: "Size of symbol changed" warnings building EPICS Base 3.14.12.2 Dirk Zimoch
- Re: "Size of symbol changed" warnings building EPICS Base 3.14.12.2 Andrew Johnson
RE: Invitation to test cothread.catools release candidate michael.abbott
RE: SmarAct / SmarPod ronaldo.mercado
<2012>
<2012>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
