g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: RE: SmarAct / SmarPod
From: Emma Shepherd <Emma.Shepherd@synchrotron.org.au>
To: "Gofron, Kazimierz" <kgofron@bnl.gov>, EPICS Tech Talk <tech-talk@aps.anl.gov>
Cc: "paul.dunne@diamond.ac.uk" <paul.dunne@diamond.ac.uk>, "lee.hudson@diamond.ac.uk" <lee.hudson@diamond.ac.uk>
Date: Tue, 13 Mar 2012 13:15:19 +1100
Hi Gofron,
As you might have gathered if your e-mail bounced, I’m not currently working at Diamond (I’ve moved to the Australian synchrotron) – but I did notice your message on tech-talk.  I’m forwarding it to Lee and Paul who are still at Diamond and might be better able to answer your question....
Lee/Paul – please could you give us an update on the performance with the SDC controller?
Emma
From: tech-talk-bounces@aps.anl.gov [mailto:tech-talk-bounces@aps.anl.gov] On Behalf Of Gofron, Kazimierz
Sent: Tuesday, 13 March 2012 3:03 AM
To: tech-talk@aps.anl.gov
Cc: emma.shepherd@diamond.ac.uk
Subject: SmarAct / SmarPod
Ernest and Emma,
We are considering purchase of the SmarPod as well, and deciding on the control.
Were you able to control SmarPod using DeltaTau and SDC (step and direction) control with the same precision as MCS controller? Or did you decide on MCS RS-232 / USB control? If you are using the MCS, did you develop EPICS driver?
Kazimierz Gofron
NSLS-II
Brookhaven National Laboratory
(p) +1 (631) 344 5283
(f) +1 (631) 344 8085
(e) kgofron@bnl.gov
(w) www.bnl.gov/nsls2
Subject:
Re: SmarAct positioner control system
"Ernest L. Williams Jr." <ernesto@slac.stanford.edu>
To:
"emma.shepherd@diamond.ac.uk" <emma.shepherd@diamond.ac.uk>
Cc:
"tech-talk@aps.anl.gov" <tech-talk@aps.anl.gov>
Date:
Tue, 12 Jul 2011 10:21:33 -0700
emma.shepherd@diamond.ac.uk wrote:
Hi Ernest,
We decided to buy the SDC (step and direction) controller in the end, which we can control directly from our Delta Tau hardware.
What is the overall experience with Delta Tau? Have you standardize on Delta Tau for all of your motion control needs.?
  However we've been having some problems with repeatability, so we might be looking into other options - the MCS RS-232 controller could be a possibility.  Let us know how you get on.
Thanks for the information.
We will also investigate the IMS solution implemented by our colleagues that support Photon Controls and Data Acquisition at LCLS.
The are using MForce Drive/Controller which interface to RS422/RS485.
http://imshome.com/products/mforce_powerdrive_mfi.html
Cheers,
Ernest
Cheers,
Emma
-----Original Message-----
From: Ernest L. Williams Jr. [mailto:ernesto@slac.stanford.edu]
Sent: 11 July 2011 21:16
To: Shepherd, Emma (DLSLtd,RAL,DIA)
Cc: tech-talk@aps.anl.gov
Subject: Re: SmarAct positioner control system
Hi all,
I haven't found anything on the EPICS website, but thought it was
worth
asking just in case.  Has anybody come across any EPICS support for
the
SmarAct MCS (Modular Control System)?  It uses an RS-232 interface to
control 3 positioners with sensor feedback.
We are also interested in the SmarAct as well.
We are looking at the  "MCS-3C-IDS, RS-232 Interface"
The idea is to add this support to the motor support package via
asynPortDriver
Ernest
Emma
This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you.
RE: SmarAct / SmarPod ronaldo.mercado
SmarAct / SmarPod Gofron, Kazimierz
Prev: Re: Invitation to test cothread.catools release candidate Michael Davidsaver
Next: RE: Invitation to test cothread.catools release candidate michael.abbott
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Prev: SmarAct / SmarPod Gofron, Kazimierz
Next: RE: SmarAct / SmarPod ronaldo.mercado
ANJ, 27 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
