g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: Re: Invitation to test cothread.catools release candidate
To: tech-talk@aps.anl.gov
Date: Mon, 12 Mar 2012 19:02:22 -0400
Hello Matt,
What initially attracted me to cothread was the simple yet powerful API of catools. It took me a while to appreciate the cooperative threading aspect. I think this was mainly because it differs from the OS threading APIs I was used to. Considered from the prospective of a new programmer without such a bias, I would agree with Michael Abbott that it is easier to learn.
On 3/12/2012 12:17 PM, Matt Newville wrote:
With Python threads it seems to me that the biggest down side of cothread, that there is only one thread of
execution, has much less impact, as Python only ever executes one thread at a time in the interpreter anyway!
To me, this would seem to have very little to do with Channel Access,
and more to do with python's threading implementation.  Is that a fair
characterization?  If so, should it be a separate python package,
useful outside of the scope of Channel Access?
(For the audience, what is being referred to is the Global Interpreter Lock)
http://wiki.python.org/moin/GlobalInterpreterLock
Coding with callbacks requires a continuation style of programming mixed with threading based events when you need
to resynchronise with the original caller.  This is definitely harder to write, particularly when exceptions and
error handling need to be taken into account.
I'm not sure I'm following you here.  Concrete examples would be nice.
I don't have any examples showing both ways, mostly because with cothreads I can happily avoid continuation passing.
There are some related examples from the Twisted library's inlineCallbacks feature. This is the first concise example I could find:
http://hackedbellini.org/development/writing-asynchronous-python-code-with-twisted-using-inlinecallbacks/
Note that while the syntax and effect are similar, the implementation is much different (less general, but more portable). It is not saving the stack, but rather taking advantage of the fact that python generators are functions with multiple entry points.
   for pvname in list_of_pvnames:
       print caget(pvname)
Please consider that catools.caget can accept a list of pvs directly.
  R = caget(list_of_pvnames)
This can be combined a FORMAT_* specifier to get metadata as well. Oh, and it works for a list of PVs with mixed types.
>>> caget(['INJ-TS{EVG-EvtClk}RFFreq-SP', 'LN-RF:PB{Cav}Message-I'], format=FORMAT_TIME)
[499.68000000000001, 'Socket Error: No route to host']
When I discuss cothread/catools I say that it is deceptively simple in the best way. It is simple to use when you're starting. Later, when you need more, you discover that its already there.
Michael Davidsaver
NSLSII Controls Group
Brookhaven National Lab
Invitation to test cothread.catools release candidate michael.abbott
Re: Invitation to test cothread.catools release candidate Matt Newville
RE: Invitation to test cothread.catools release candidate michael.abbott
Prev: Re: MVME2434-1 Till Straumann
Next: RE: SmarAct / SmarPod Emma Shepherd
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Prev: Re: Invitation to test cothread.catools release candidate Matt Newville
Next: RE: Invitation to test cothread.catools release candidate michael.abbott
ANJ, 27 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
