g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: RE: Fwd:
To: <smzhaq@gmail.com>, <tech-talk@aps.anl.gov>
Date: Mon, 12 Mar 2012 13:22:46 +0000
From: tech-talk-bounces@aps.anl.gov [mailto:tech-talk-
> I am trying to load a small epics application into the mvme2304 board
> in VME crate. After following the instructions  from tutorial from
> EPICS web site, (and running the "NBO" command from PPC-BUG of the
> cpu,) I still do not find it is working.
Alas, I am wholly unfamiliar with RTEMS, but a few obvious things spring to mind:
1. Is there a shell, do you know, built into your RTEMS image?
2. What serial settings are built into your RTEMS image?
3. Indeed, is your RTEMS image even built to use the right serial device?
Don't worry about EPICS until RTEMS boots...
Hopefully other people on this list have more of a clue about RTEMS.
Fwd: Qazi Zia-ul-Haque
Prev: Fwd: Qazi Zia-ul-Haque
Next: RE: Invitation to test cothread.catools release candidate michael.abbott
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Next: RE: Fwd: michael.abbott
ANJ, 27 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
