Hi all
I am facing problems while after installing EPICS3.14.12.2. in a machine. The EPICS apparently installed successfully without reporting errors. An example application was also made and run using makeBaseApp.pl utility. However the problem is being faced while trying to access the CA variables using channel access. Path to the directory containing caget is added and caget is being called but returning failure in connecting to channel i.e. connectivity to CA variables is not being established. I need your kind guidance for it. With Best Regards -- Zia
Control Engineer Synchrotron-light for Experimental Sciences and Applications in the Middle East (SESAME) P. O. Box 7, Allan 19252, Jordan Phone: +962-5-3511348 Ext: 239 Cell: +962-79-5295527 Res: +962-5-3511463
| ANJ, 27 Nov 2012 |
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
