Subject: |
example_registerRecordDeviceDriver.cpp:238: undefined reference to `pvar_drvet_drvBPEM' error |
"Bai Jiaoni" <[email protected]> |
To: |
[email protected] |
Date: |
Fri, 9 Mar 2012 10:18:19 +0800 (CST) |
Hello,
When i compiler my code on epics 3.14, it report "example_registerRecordDeviceDriver.cpp:238: undefined reference to `pvar_drvet_drvBPEM'". How should I solve it? Thank
you.
My .dbd file is as following:
device(ao,VME_IO, devAoBPEM,"BPEM")
device(waveform,VME_IO, devWfBPEM,"BPEM")
driver(drvBPEM)
My Makefile is as following:
TOP=../..
include $(TOP)/configure/CONFIG
# ADD MACRO DEFINITIONS AFTER THIS LINE
# Only build for "hard" IOC's
#ifneq ($(findstring Host, $(VALID_BUILDS)),)
# VALID_BUILDS = Host
#endif
# Build an IOC support library
LIBRARY_IOC += xxxSupport
# xxxRecord.h will be created from xxxRecord.dbd
DBDINC += xxxRecord
# install devXxxSoft.dbd into <top>/dbd
DBD += xxxSupport.dbd
# The following are compiled and added to the Support library
xxxSupport_SRCS += xxxRecord.c
xxxSupport_SRCS += devXxxSoft.c
xxxSupport_LIBS += $(EPICS_BASE_IOC_LIBS)
# build an ioc application
PROD_IOC = example
# example.dbd will be created and installed
DBD += example.dbd
# example.dbd will be made up from these files:
example_DBD += base.dbd
example_DBD += xxxSupport.dbd
example_DBD += dbSubExample.dbd
example_DBD += exampleHello.dbd
example_DBD += BPEM.dbd
# <name>_registerRecordDeviceDriver.cpp will be created from <name>.dbd
example_SRCS += example_registerRecordDeviceDriver.cpp
example_SRCS_DEFAULT += exampleMain.cpp
example_SRCS_vxWorks += -nil-
# Add locally compiled object code
example_SRCS += dbSubExample.c
example_SRCS += exampleHello.c
example_SRCS_vxWorks += drvBPEM.c
example_SRCS_vxWorks += devBPEM.c
example_SRCS_vxWorks += universe.c
example_SRCS_vxWorks += dmaLib.c
# The following adds support from base/src/vxWorks
example_OBJS_vxWorks += $(EPICS_BASE_BIN)/vxComLibrary
example_LIBS += xxxSupport
# NOTE: To build SNL programs, SNCSEQ must be defined
# in the <top>/configure/RELEASE file
ifneq ($(SNCSEQ),)
# This builds sncExample as a component of example
example_SNCFLAGS += +r
example_DBD += sncExample.dbd
example_SRCS += sncExample.stt
example_LIBS += seq pv
# The following builds sncProgram as a standalone application
PROD_HOST += sncProgram
sncProgram_SNCFLAGS += +m
sncProgram_SRCS += sncProgram.st
sncProgram_LIBS += seq pv
sncProgram_LIBS += $(EPICS_BASE_HOST_LIBS)
endif
example_LIBS += $(EPICS_BASE_IOC_LIBS)
include $(TOP)/configure/RULES
# ADD RULES AFTER THIS LINE
Jiaoni Bai
Institute of High Energy Physics, CAS
NO.13 of Yuquan Road Haidian, Beijing China
Re: Converting driver of R3.13 Applications to R3.14 problems Andrew Johnson
Cancel the question Bai Jiaoni
<2012>
<2012>
