Hello, For a few of my soft records, I used to read the INP field directly with a command like [driver code] myStatus=sscanf(psi->inp.value.instio.string, "@lm=%d df=%[^\n]", &myLogMark, p_myDateFormat); [/driver code] It turns out this method doesn't work correctly anymore. Indeed the psi->inp.value.instio.string is truncated at the first 'space' char. In my case, that means, it cannot scanf the 'df= ...' I also noticed that I now have to include the '@' char, when before I didn't have to. That change appeared between 3.14.8 and
3.14.11 What is the correct way to read the INP field now? -- Emmanuel
| ANJ, 27 Nov 2012 |
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
