1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: "Size of symbol changed" warnings building EPICS Base 3.14.12.2
To: [email protected]
Date: Wed, 7 Mar 2012 11:02:30 -0600
Hi Dirk,
> On 3/7/12 2:50 AM, Dirk Zimoch wrote:
> > These two functions,
> > epicsSingleton<localHostName>::reference::~reference(void) and
> > epicsSingleton<localHostName>::reference::operator->(void) both
> > contain 'assert' (see src/libCom/cxxTemplates/epicsSingleton.h).
> > 'assert' is a macro:
> > #   define assert(exp) ((exp) ? (void)0 : \
> >         epicsAssert(__FILE__, __LINE__, #exp, epicsAssertAuthor))
> > Depending on the optimization level, '(void)0' may be eliminated
> > and the code becomes shorter (by 4 bytes = 1 PPC instruction).
> > Try to 'make clean' in the epics base top directory and compile
> > again.
The problem is more subtle than that, although I suspect that different
optimization levels is probably the underlying cause.
Remember Lewis is using a very old version of g++, from back when C++
templates were new; my guess is that ldppc is recompiling the template
instances it needs to link the code behind the scenes, but it wasn't told the
optimization level that g++ppc used to compile the instances that appear in
the .o files it's linking with so it doesn't get the same length code and
generates that warning.  There may be a flag we could turn on to show more
about what's going on inside ldppc, but it's really not worth looking into
IMHO; better to spend the time upgrading to vxWorks 5.5.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Re: "Size of symbol changed" warnings building EPICS Base 3.14.12.2 Dirk Zimoch
"Size of symbol changed" warnings building EPICS Base 3.14.12.2 J. Lewis Muir
Re: "Size of symbol changed" warnings building EPICS Base 3.14.12.2 J. Lewis Muir
Prev: motor module R6-7-1 released Ron Sluiter
Next: COV service for EPICS BACnet-driver is ready. Webb, Steven B.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: "Size of symbol changed" warnings building EPICS Base 3.14.12.2 J. Lewis Muir
Next: Re: "Size of symbol changed" warnings building EPICS Base 3.14.12.2 Dirk Zimoch
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
