1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: "Size of symbol changed" warnings building EPICS Base 3.14.12.2
To: Dirk Zimoch <[email protected]>
Date: Wed, 07 Mar 2012 10:02:38 -0600
On 3/7/12 2:50 AM, Dirk Zimoch wrote:
> Hi Lewis,
> Can it be that you did not do a "make clean" when you changed
> the optimization level?
> I am speculating a bit now:
> These two functions,
> epicsSingleton<localHostName>::reference::~reference(void) and
> epicsSingleton<localHostName>::reference::operator->(void) both
> contain 'assert' (see src/libCom/cxxTemplates/epicsSingleton.h).
> 'assert' is a macro:
> #   define assert(exp) ((exp) ? (void)0 : \
>         epicsAssert(__FILE__, __LINE__, #exp, epicsAssertAuthor))
> Depending on the optimization level, '(void)0' may be eliminated
> and the code becomes shorter (by 4 bytes = 1 PPC instruction).
> Try to 'make clean' in the epics base top directory and compile
> again.
Hi, Dirk.
Thanks for the suggestion.  I'm pretty sure I did a "make
clean", but I tried again just now to be sure, and the problem
still remains. :-(
Lewis
Re: "Size of symbol changed" warnings building EPICS Base 3.14.12.2 Andrew Johnson
"Size of symbol changed" warnings building EPICS Base 3.14.12.2 J. Lewis Muir
Re: "Size of symbol changed" warnings building EPICS Base 3.14.12.2 J. Lewis Muir
Re: "Size of symbol changed" warnings building EPICS Base 3.14.12.2 Dirk Zimoch
Prev: Re: References about EPICS Matthias Clausen
Next: motor module R6-7-1 released Ron Sluiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: "Size of symbol changed" warnings building EPICS Base 3.14.12.2 Dirk Zimoch
Next: Re: "Size of symbol changed" warnings building EPICS Base 3.14.12.2 Andrew Johnson
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
