g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: TDS 3000 on win32-x86
To: EPICS Tech Talk <tech-talk@aps.anl.gov>
Date: Mon, 5 Mar 2012 18:58:22 +0400
Mark,
Thanks for such a quick response! Yeah, I forgot to include that dbd. I have recompiled and here what I've got:
drvAsynIPPortConfigure("L0", "172.20.92.3", 0, 0, 0)
drvAsynIPPortConfigure: "172.20.92.3" is not of the form "<host>:<port> [protocol]"
Port L0 connectDevice failed: asynManager:connectDevice port L0 not found
asynOctetSetOutputEos("L0",0,"\n")
Which port should I use: 172.20.92.3:80? The 80th? I don't know actually, but in the Tektronix's prefs (Instrument Setup) I see the option Http Port: 80. Though, I don't know this is the correct port. I presume, it's just for the simple http access via the internet browser. I'm stuck. Please, help!
PAvel
On Mon, Mar 5, 2012 at 6:38 PM, Mark Rivers <rivers@cars.uchicago.edu> wrote:
Hi Pavel,
This error
ERROR: vxi11Configure is not supported on WIN32
is expected because there is no support for VXI-11 on win32-x86, because we don't have an implementation of Sun RPC for win32-x86, which the VXI-11 support requires.
However, this error:
st.cmd -- Line 50 -- Command drvAsynIPPortConfigure not found.
is not expected.  The drvAsynIPPortConfigure command works fine on win32-x86.  You must have a mistake in building your application, perhaps you forgot to include "drvAsynIPPort.dbd" in your dbd file.
From: tech-talk-bounces@aps.anl.gov [tech-talk-bounces@aps.anl.gov] on behalf of Pavel Masloff [pavel.masloff@gmail.com]
Sent: Monday, March 05, 2012 8:31 AM
To: EPICS Tech Talk; Nicholas P. DiMonte
Hi Nick et al. :
I am trying to use your Tektronix TDS-3000 support on win32-x86. And I have found that it neither works via "Direct network connection" nor "GPIB/LAN connection":
Is there a possibility to talk to the TDS 3054C device any other way on win32? If so, could you give me a hint?
If using "Remote serial port", the following errors occur:
asynOctetSetInputEos("L0",0,"\n")
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Phone: +7 (812) 461 01 01
Best regards,
Pavel Maslov, MS
Best regards,
Pavel Maslov, MS
RE: TDS 3000 on win32-x86 Mark Rivers
TDS 3000 on win32-x86 Pavel Masloff
Prev: RE: BOY FAQ Chen, Xihui
Next: RE: TDS 3000 on win32-x86 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Prev: RE: TDS 3000 on win32-x86 Mark Rivers
ANJ, 27 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
