g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: RE: BOY FAQ
To: "'John William Sinclair'" <sinclairjw@ornl.gov>, Tech-talk <tech-talk@aps.anl.gov>
Date: Fri, 2 Mar 2012 21:45:40 +0000
I just have documented those problems:
: Failed to read color definition file
: Failed to read font definition file
To fix colors and fonts select CSS perspective; go Edit->Preferences...; CSS Application -> Display -> Boy; Browse for local color.def and font.def files. Confirm your selections.
Let me know directly if instructions are not clear.
Oksana
> -----Original Message-----
> From: tech-talk-bounces@aps.anl.gov [mailto:tech-talk-bounces@aps.anl.gov] On
> Behalf Of John William Sinclair
> Sent: Friday, March 02, 2012 4:27 PM
> To: Tech-talk
> Subject: BOY FAQ
> I have downloaded the NSLS CSS product.
> After changing various config parameters, probe and data browser both work but
> BOY does not (pv does not resolve).
> One known problem: I have neither color.def nor font.def and the documentation
> complains about an invalid url when I click on the link references. Does someone
> have a link to documentation for these files? A simple working example would also
> be appreciated. Do I need these files or will the system supply defaults if they are
> missing?
> Thanks,
> John Sinclair
BOY FAQ John William Sinclair
Prev: BOY FAQ John William Sinclair
Next: ASYN Communication through windows serial port (via USB) Josh Stein
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Next: BOY FAQ John William Sinclair
ANJ, 27 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
