1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: CSS workspace lock, prompt Re: BOY FAQ
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 2 Mar 2012 12:27:04 -0500
Hi:
On 3/2/12 12:08 , "Michael Davidsaver" <[email protected]> wrote:
>Also, has anyone found a way to add projects to a workspace
>automatically or from the command line?
There same common startup code extension point that has the "workspace"
parameter also has a "project" parameter:
<extension point="org.csstudio.startup.module">
  <project class="org.csstudio.startup.module.defaults.DefaultProject"/>
   </extension>
If you use that, you always get an open "CSS" project into your workspace.
If you leave it out, you get no pre-defined projects.
We could tweak the DefaultProject code to allow adding more than just
"CSS",
or you can of course create your own implementation.
-Kay
Re: CSS workspace lock, prompt Re: BOY FAQ Michael Davidsaver
Prev: Re: QT-based tools: Expressions of interest requested djquock
Next: Re: CSS workspace lock, prompt Re: BOY FAQ Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: CSS workspace lock, prompt Re: BOY FAQ Michael Davidsaver
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
