I updated my seq module to use INSTALL_LOCATION and
can confirm that it works.
- Bruce
On 02/27/2012 01:52 PM, Janet Anderson wrote:
Hi Benjamin,
I think it would be ok to change TOP to INSTALL_LOCATION in
Bruce's
version of the code and include it in the next
sequencer release. To use the snc tool, the build needs to know
its
location. In Bruce's code, if SNCSEQ or SEQ is defined
we are building a module or ioc-application which has defined the
sequencer in its RELEASE file using SNCSEQ or SEQ,
and the snc tool will be found in the SNCSEQ or SEQ bin directory.
Otherwise we are building the sequencer module
and the snc tool will be found in the INSTALL_LOCATION bin
directory.
Janet
Benjamin Franksen wrote:
Hi Janet, Andrew, etc
recently there was mention of a build problem when using epics base >=
3.14.12 and user defined rules. A solution was proposed by Bruce Hill:
On Thursday, February 02, 2012, Bruce Hill wrote:
We ran into this problem recently, trying to build std-2-9
with seq-2.1.2 and fixed it in the seq configure/RULES_BUILD.
It looked to me like it resulted from RULES_TOP not being
defined by base starting w/ R3-14-12. This kept SNC from
being defined correctly in seq/configure/RULES_BUILD.
There's probably other ways to solve this, but we got it to
work with the attached patch, also shown below.
For better comparison, here is the current (seq-2.1.4) version:
ifdef RULES_TOP
# EPICS base R3.14.7 and later
SNC = $(RULES_TOP)/bin/$(EPICS_HOST_ARCH)/snc$(HOSTEXE)
else
# EPICS base R3.14.6 and earlier
ifndef SNC
SNC = $(SNCSEQ_HOST_BIN)/snc$(HOSTEXE)
endif
endif
and this is Bruce's version:
ifdef SNCSEQ
SNC = $(SNCSEQ)/bin/$(EPICS_HOST_ARCH)/snc$(HOSTEXE)
else
ifdef SEQ
SNC = $(SEQ)/bin/$(EPICS_HOST_ARCH)/snc$(HOSTEXE)
else
SNC = $(TOP)/bin/$(EPICS_HOST_ARCH)/snc$(HOSTEXE)
endif
endif
Should I include this change in 2.1.5?
Janet, is this how I should do it?
Cheers
Ben
--- configure/RULES_BUILD (revision 8496)
+++ configure/RULES_BUILD (revision 8644)
@@ -33,15 +33,25 @@
# snc executable
-ifdef RULES_TOP
- # EPICS base R3.14.7 and later
- SNC = $(RULES_TOP)/bin/$(EPICS_HOST_ARCH)/snc$(HOSTEXE)
+#ifdef RULES_TOP
+# # EPICS base R3.14.7 and later
+# SNC = $(RULES_TOP)/bin/$(EPICS_HOST_ARCH)/snc$(HOSTEXE)
+#else
+# # EPICS base R3.14.6 and earlier
+# ifndef SNC
+# SNC = $(SNCSEQ_HOST_BIN)/snc$(HOSTEXE)
+# endif
+#endif
+ifdef SNCSEQ
+SNC = $(SNCSEQ)/bin/$(EPICS_HOST_ARCH)/snc$(HOSTEXE)
else
- # EPICS base R3.14.6 and earlier
- ifndef SNC
- SNC = $(SNCSEQ_HOST_BIN)/snc$(HOSTEXE)
- endif
+ifdef SEQ
+SNC = $(SEQ)/bin/$(EPICS_HOST_ARCH)/snc$(HOSTEXE)
+else
+SNC = $(TOP)/bin/$(EPICS_HOST_ARCH)/snc$(HOSTEXE)
endif
+endif
# preserve compatibility to base versions before 3.14.12
ifndef ECHO
On 01/31/2012 05:17 PM, Szalata, Zenon M. wrote:
Thanks Mark,
I tried the latest version of sequencer (R2.1.4), which did not quite
build correctly. I did not think that mattered. I now have regressed
to an earlier version of sequencer (R2.0.12) and std built without
errors.
I will look again at the R2.1.4 version of sequencer, see if I can fix
that.
Thanks again,
Zen
*Sent:* Tuesday, January 31, 2012 4:56 PM
*To:* Szalata, Zenon M.; [email protected]
*Subject:* RE: std_R3_1
femto is an SNL program. Do you have the sequencer in your
configure/RELEASE file in std?
[mailto:[email protected]] *On Behalf Of *Szalata, Zenon M.
*Sent:* Tuesday, January 31, 2012 6:44 PM
*To:* [email protected]
*Subject:* std_R3_1
Building std_R3_1 fails on RHEL6 64bit with this error:
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE
-Dlinux -D_REENTRANT -g -Wall -m64 -fPIC -MMD -I.
-I../O.Common -I. -I.. -I../../../include/os/Linux
-I../../../include
-I/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/seq/R2.1.4/include
-I/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/asyn/R4.18/include
-I/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/base/include/os/Linux
../pvHistory.c
make[3]: *** No rule to make target `femto.o', needed by `libstd.a'.
Stop.
make[3]: Leaving directory
`/afs/slac.stanford.edu/g/testfac/vol1/rhel6/epics/R3.14.12.2/modules/s
td/R3.1/stdApp/src/O.linux-x86_64'
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory
td/R3.1/stdApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory
td/R3.1/stdApp'
make: *** [stdApp.install] Error 2
I did not try building on other architectures, so I don’t know the
extent of my problem.
What am I missing on this computer?
Thanks for any help,
Zen
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführerin: Prof. Dr. Anke Rita Kaysser-Pyzalla
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
- std_R3_1 Szalata, Zenon M.
- RE: std_R3_1 Szalata, Zenon M.
- Re: std_R3_1 Bruce Hill
- Sequencer build rules Benjamin Franksen
- Re: Sequencer build rules Janet Anderson
Using EDM on Fedora linux, font problem Chengcheng Xu
<2012>
mcaR7-0 Szalata, Zenon M.
<2012>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
