1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Search for disconnected channels
To: Ralph Lange <[email protected]>
Date: Thu, 23 Feb 2012 11:10:09 -0500
I was thinking of a local solution for one process on one host, but I will consider your global solution. I'm not sure I want every client restarting their searches for disconnected channels.
  Thanks.
Ralph Lange wrote:
Chris,
You need a beacon anomaly that your clients can see, so they rebroadcast
their unresolved names.
Quick-and-dirty solution:
The easiest way to create a beacon anomaly is to start up an IOC. Create
an empty soft IOC on a machine on the clients' network (the softIoc
executable from base is fine). Set up a cron job that starts the IOC,
waits a second, then kills it.
Whenever that cron job runs, all clients on the local network will try
to resolve their channels.
~Ralph
On 23.02.2012 14:18, Chris Slominski wrote:
I want to be able to force my EPICS channel access client to begin a
new search for currently disconnected channels.We have small short
term pc104 iocs come and go and sometimes they are  not configured
correctly to broadcast when they have been booted up. A client
listening to the channels won't see a beacon anomaly and  begin the
channel search sequence.
I can see a couple of ways to do this.
- Send a network beacon to the CA Repeater.
- Issue a search for some non-existent channel.
Please advise on what is a good way to do this. Example code or
references to EPICS source code are very welcome, as I am neither
familiar with EPICS base software, nor am I an experienced network
programmer. My client software uses EPICS 3.13.10.
      Chris
Re: Search for disconnected channels Andrew Johnson
Re: Search for disconnected channels Ralph Lange
Search for disconnected channels Chris Slominski
Prev: RE: QT-based tools: Expressions of interest requested david.hickin
Next: RE: Best pratices for compiling dbd files for asyn base device support Abadie Lana
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Search for disconnected channels Ralph Lange
Next: Re: Search for disconnected channels Andrew Johnson
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
