1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Best pratices for compiling dbd files for asyn base device support
Date: Wed, 22 Feb 2012 11:41:25 +0100
Hi all
I would like to collect some feedback on the best things to include proper DTYP information in the dbd file when using asyn.
Currently when a driver is using EPICS device support via asyn, it has these lines in the Makefile
XX_DBD += base.dbd
XX_DBD += asyn.dbd
This will result in a dbd for the driver which includes all the combination record type/DTYP from asyn (referring lines to device(XXX)). It is fine when your driver supports all of them, but not if your driver supports part of them.
So one idea would be to modify the asyn.dbd and comment the include devEpics and add another dbd which manually lists the supported interfaces  per  device support.
Does it sounds reasonable ? any other feedback?
Thanks
Lana
RE: Best pratices for compiling dbd files for asyn base device support Mark Rivers
Problems with priorities in epicsThreadCreate (part of the EPICS OSI software layer) Goetz Pfeiffer
Re: Problems with priorities in epicsThreadCreate (part of the EPICS OSI software layer) Eric Norum
Re: Problems with priorities in epicsThreadCreate (part of the EPICS OSI software layer) Andrew Johnson
Re: Problems with priorities in epicsThreadCreate (part of the EPICS OSI software layer) Goetz Pfeiffer
Prev: Re: Problems with priorities in epicsThreadCreate (part of the EPICS OSI software layer) Goetz Pfeiffer
Next: Re: Problems with priorities in epicsThreadCreate (part of the EPICS OSI software layer) Goetz Pfeiffer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: Best pratices for compiling dbd files for asyn base device support Mark Rivers
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
