1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Connection to Siemens S7 PLC
To: Konrad Gajewski <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 21 Feb 2012 22:42:11 +0100
For ITER, we evaluated two options (but only with S7/300 and S7/400 CPUs): the s7plc device support from SLS that use dedicated Ethernet frames and the native S7 protocol.
For the 2nd option, we used libnodave, the open software lib available for Linux (that is supposed to work with s200). This option is also used at CERN. For windows users, the Siemens libs certainly do the job.
We choose s7plc for performances reasons so we stopped all development on device support with libnodave.
Native S7 protocols is therefore also an option but I don't think a device support exists.
We can provide a very incomplete example of such a device support if usefull.
Franck
Franck Di Maio
CODAC System Designer
CODAC Section
ITER Organization, Building 519/027, CHD, Control System Division
Route de Vinon sur Verdon - 13115 St Paul Lez Durance - France
Phone: +33 4 42 17 64 05
-----Original Message-----
Sent: 21 February 2012 16:46
To: Konrad Gajewski; [email protected]
Can the  MODBUS driver be used with TCP on that family of PLCs?
From: [email protected] [[email protected]] on behalf of Konrad Gajewski [[email protected]]
Sent: Tuesday, February 21, 2012 6:13 AM
To: [email protected]
Subject: Connection to Siemens S7 PLC
Hello everybody,
I'm new to EPICS and I am planning  to control Siemens Simatic S7-200 PLC. I have looked in EPIC documentation and found at least two ways to connect the PLC:
1. via MODBUS (Asyn) driver over the serial connection (using Siemens MODBUS RTU library) 2. using S7plc driver via TCP/IP and a CP 243-1 Ethernet module.
The programming of the PLC is done using Step-7 Micro/WIN V4.0.
Unfortunately I can't open the example STEP 7 PLC project  (for S7plc
driver) in Step-7 Micro/WIN.
Do you have any experience with such a configuration or maybe with S7-1200? Are there any better options?
   Konrad
Konrad Gajewski
Senior Research Engineer
Uppsala University                    Tel:    +46-18-4713888
The Svedberg Laboratory               mailto:[email protected]
Box 533, S-751 21 Uppsala, Sweden
http://www.tsl.uu.se/
Connection to Siemens S7 PLC Konrad Gajewski
RE: Connection to Siemens S7 PLC Mark Rivers
Prev: QT-based tools: Expressions of interest requested Andrew Johnson
Next: CSS X-Y Graph John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Connection to Siemens S7 PLC Mark Rivers
Next: RE: Connection to Siemens S7 PLC Mueller, Joachim
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
