On 2012-02-16 Dirk Zimoch wrote:
> This is a typical symptom when your EPICS base binaries do not match the
> dbd files. For example when you load a EPICS 3.14.12 dbd file into a
> EPICS 3.14.8 IOC.
... which is why makeBaseApp applications run checkRelease at build time to
compare the RELEASE file paths for the application with those of all its
support modules. If you disable checking by setting CHECK_RELEASE=NO you're
arming your own foot-gun (recent versions of Base do print a warning in this
case; if I need to disable the check I *always* set it to WARN instead of NO).
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
- registerRecordDeviceDriver fails at registryRecordTypeFind Matt Rippa
- Re: registerRecordDeviceDriver fails at registryRecordTypeFind Dirk Zimoch
EDM segmentation fault in colorInfoClass Shankar, Murali
<2012>
Modbus/serial using Stream? Ralph Lange
<2012>
