1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: registerRecordDeviceDriver fails at registryRecordTypeFind
Date: Wed, 15 Feb 2012 15:16:12 -1000
I found my epics-base was not installed where I thought it was.
My IOC works again.
FWIW, I thought this kind of patch would've helped me. Not too
clean with the global flag, but gives something more to go on.
-Matt
--- base-3.14.12.1/src/registry/registryCommon.c
2012-02-15 15:00:15.329683000 -1000
+++ /tmp/base-3.14.12.1/src/registry/registryCommon.c
2011-04-26 10:40:09.000000000 -1000
@@ -22,7 +22,6 @@
 #include "registryDriverSupport.h"
 #include "registryCommon.h"
-int debugRegistryRTF = 0;
 void epicsShareAPI registerRecordTypes(DBBASE *pbase, int
nRecordTypes,
     const char* const* recordTypeNames, const
recordTypeLocation *rtl)
@@ -33,8 +32,6 @@
         computeSizeOffset sizeOffset;
         DBENTRY dbEntry;
-        if (debugRegistryRTF)
-            printf("registryRecordTypeFind on >>>%s<<<\n",
recordTypeNames[i]);
         if(registryRecordTypeFind(recordTypeNames[i])) continue;
         if(!registryRecordTypeAdd(recordTypeNames[i],&rtl[i])) {
             errlogPrintf("registryRecordTypeAdd failed %s\n",
On 02/14/2012 03:09 PM, Matt Rippa wrote:
> Hi,
> I have a new vxworks(5.5.1) IOC (3.14.12.1) application crashing
> on startup at the registry stage. I suspect something like a
> missing DBD entry in my Makefile. I've rebuilt everything
> referenced in my configure/RELEASE file from epics-base to my
> application.
> Is there an easy way to get more information before the crash?
> Thanks for the help,
> Matt
> ld 0,0, "gmosdc.munch"
> BSP routine sysAtReboot() not found, epicsExit() will not be
> called by reboot.  For reduced functionality, call
>     rebootHookAdd(epicsExitCallAtExits)
> value = 1038310096 = 0x3de35ad0 = ipAddrToAsciiEnginePrivate
> type_info node + 0xb40
> # Work around to allow epics to close network connections
> # nicely on exit. See:
> # http://www.aps.anl.gov/epics/tech-talk/2008/msg00259.php
> value = 0 = 0x0
> ## Register all support components
> cd top
> value = 0 = 0x0
> dbLoadDatabase("dbd/gmosdc.dbd",0,0)
> value = 0 = 0x0
> gmosdc_registerRecordDeviceDriver(pdbbase)
> program
> Exception current instruction address: 0x00000004
> Machine Status Register: 0x
> 0008b030
> Condition Register: 0x8000208420c01c
>  vxTaskEntry    +68 : shell ()
> 1c943c shell          +190: 1c9468 ()
> 1c9668 shell          +3bc: execute ()
> 1c97ec execute        +d8 : yyparse ()
> 1e5ea4 yyparse        +71c: 1e423c ()
> 1e43c0 yystart        +96c: gmosdc_registerRecordDeviceDriver ()
> 3db54210 gmosdc_registerRecordDeviceDriver+b8 :
> registerRecordTypes ()
> 3dc246c0 registerRecordTypes+ac : registryRecordTypeFind ()
> 3dc243a8 registryRecordTypeFind+28 : 4 ()
> shell restarted.
registerRecordDeviceDriver fails at registryRecordTypeFind Matt Rippa
Prev: RE: Precise time beyond 2038 Di Maio Franck
Next: Re: epics-arduino Noboru Yamamoto
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: registerRecordDeviceDriver fails at registryRecordTypeFind Matt Rippa
Next: Re: registerRecordDeviceDriver fails at registryRecordTypeFind Dirk Zimoch
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
