g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: cothread time stamp problem
To: "michael.abbott@diamond.ac.uk" <michael.abbott@diamond.ac.uk>
Cc: "tech-talk@aps.anl.gov" <tech-talk@aps.anl.gov>
Date: Sat, 11 Feb 2012 03:58:47 +0000
Hi Michael,
What is the time policy used in cothread to retrieve ioc time stamp?
I am using cothread 2.3, and found the time is shifted by a constant value relative to local timezone.
For example, in US EST time, to get time stamp in Python, I use val = caget(pv, format=FORMAT_TIME).
However, the time.localtime(val.timestamp)=real local time + 5 hours, and
time.gmtime(val.timestamp) = real local time + 10 hours = real UTC time + 5 hours,
which looks shifting to wrong direction.
Here is my test case:
$ caget -d 20 test
test
    Native data type: DBF_DOUBLE
    Request type:     DBR_TIME_DOUBLE
    Element count:    1
    Value:            1.9
    Timestamp:        2012-02-10 15:27:21.645387
    Status:           NO_ALARM
    Severity:         NO_ALARM
$ python
>>> from cothread.catools import *
>>> import time
>>> v=caget('test', format=FORMAT_TIME)
>>> time.localtime(v.timestamp)
time.struct_time(tm_year=2012, tm_mon=2, tm_mday=10, tm_hour=20, tm_min=27, tm_sec=21, tm_wday=4, tm_yday=41, tm_isdst=0)
>>> time.gmtime(v.timestamp)
time.struct_time(tm_year=2012, tm_mon=2, tm_mday=11, tm_hour=1, tm_min=27, tm_sec=21, tm_wday=5, tm_yday=42, tm_isdst=0)
Any suggestion?
Guobao
RE: cothread time stamp problem michael.abbott
Prev: Re: Waveform record missing fields Andrew Johnson
Next: Re: DRVL, DRVH, HOPR, LOPR Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Next: RE: cothread time stamp problem michael.abbott
ANJ, 27 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
