1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Waveform record missing fields
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 10 Feb 2012 12:28:58 -0800
Hi Mark,
> NUSE: The number of elements in the waveform to actually use.  Must be <=NELM.
I think you intend this record to be something you can caput?  If yes, maybe better to call it something other than NUSE since NUSE for a compressRecord is not modifiable (NUSE for a compress is the same concept as NORD for a waveform).  Maybe "NINP" instead.
> Also, the record does not post monitors on the BUSY or NORD fields.  Should this be the
> responsibility of device support, or does that code belong in the record?
I think the code belongs in the record.  It would be very nice to have monitors on NORD!
Thank you!
Stephanie Allison
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf
> Of Mark Rivers
> Sent: Friday, February 10, 2012 10:50 AM
> To: [email protected]
> Subject: Waveform record missing fields
> Folks,
> All versions of the EPICS Record Reference Manual from 3.13 to 3.14.12.2 document the
> following 2 fields in the waveform record:
> RATE Sampling Rate       Some device support modules may find this useful.
> PTSS Pre-trigger Samples Some device support modules may find this useful.
> I really need to use these 2 fields in some new asyn device support I am writing.  (This
> device support will allow me to remove the dependence of areaDetector on mca).
> But these fields do not actually exist in the waveform record, at least for any version of base
> from 3.14.8.2 to 3.14.12.2!
> I cannot find anything in the 3.13 or 3.14 release notes that mentions removing these fields.
> Questions:
> - Did these fields ever exist?
> - Should they be added?
> - If so, then while we are adding these fields are there others we should also add that would
> not break backward compatibility?
> Here are is one that I can think of:
> Thanks,
> Mark
Waveform record missing fields Mark Rivers
Prev: Re: Waveform record missing fields Michael Davidsaver
Next: Re: Waveform record missing fields Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
