1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: How to set the parameters of the mrmEvrSetupVME or mrmEvgSetupVME
Date: Thu, 9 Feb 2012 23:25:24 +0000
 Hi All,
       Thanks in advance.
  How to fill the parameters of the   mrmEvrSetupVME(const char *id, int slot, int base, int level, int vector ), especially for the base address and vector number para. ?
       I am using the MVME3100 +  VME-EVR-230RF /  VME-EVG-230  board ,standard VME crate  . The EVR & EVG 230 boards, I set them as the slot 2 by setting the jumbers
according to the VME specification datasheet as the following .
 Slot GAP* GA4* GA3* GA2* GA1* GA0*
No.   Pin    Pin    Pin     Pin    Pin     Pin
1  Open  Open Open  Open Open GND
2  Open  Open Open  Open GND Open
3  GND   Open Open  Open GND GND
4  Open  Open Open  GND Open Open
5  GND   Open Open   GND Open GND
21 Open GND  Open  GND  Open  GND
     1)     I don't quite understand  the base address is decided by jumper setting.  I am not familiar with the VME protocol,   any body  tell me ,  if the slot is  2, then how
             to get  how to get the base address then ?
     2)     The EVR or EVR address space will be remapped as a part of the  address space of the MVME3100,  how to set the last param., the interrupt vector then ?
              Does the BSP layer implement a reasonable conversion or .... ?   My OS  is  RTEMS 4-9,  bsp is MVME3100 .
             How to set the last param ?   Thanks~
       Catching up time to demo,  no time to read carefully the protocols and related datasheet. Appreciate your help :) .
Best regards,
Kevin Zhu
Re: How to set the parameters of the mrmEvrSetupVME or mrmEvgSetupVME Bjorklund, Eric A
Prev: asyn and vxWorks 5.4.2 and earlier Mark Rivers
Next: Re: How to set the parameters of the mrmEvrSetupVME or mrmEvgSetupVME Bjorklund, Eric A
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: asyn and vxWorks 5.4.2 and earlier Mark Rivers
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
