1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: AsynDriver build errors on MinGW
To: "'Josh Stein'" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 9 Feb 2012 20:59:54 +0000
Hi Josh,
I don't have experience with MinGW.  However, I know that there are issues building dynamically with Cygwin, which is also the gcc compiler.
Can you try building statically?  Put the following in the base/configure/os/ /CONFIG_SITE.win32-x86-mingw.win32-x86-mingw file:
STATIC_BUILD=YES
SHARED_LIBRARIES=NO
Rebuild base and asyn and see if that fixes the problem.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Josh Stein
Sent: Thursday, February 09, 2012 9:54 AM
To: [email protected]
Subject: AsynDriver build errors on MinGW
Here I go again with MinGW...
I'm attempting to build the AsynDriver module on a windows box; during
the make in /modules/asyn4-18 I get the following error:
g++ -o asyn.dll -shared -Wl,--out-implib,asyn.lib
-LC:\base-3.14.12.2\lib\win32-x86-mingw       -m32
     asynManager.o epicsInterruptibleSyscall.o asynGpib.o
drvAsynSerialPortWin32.o drvAsynIPPort.o drvAsynIPServerPort.o
asynInt32Base.o asynInt32SyncIO.o asynInt8ArrayBase.o
asynInt8ArraySyncIO.o asynInt16ArrayBase.o asynInt16ArraySyncIO.o
asynInt32ArrayBase.o asynInt32ArraySyncIO.o asynUInt32DigitalBase.o
asynUInt32DigitalSyncIO.o asynFloat64Base.o asynFloat64SyncIO.o
asynFloat32ArrayBase.o asynFloat32ArraySyncIO.o asynFloat64ArrayBase.o
asynFloat64ArraySyncIO.o asynOctetBase.o asynOctetSyncIO.o
asynGenericPointerBase.o asynGenericPointerSyncIO.o asynCommonSyncIO.o
asynStandardInterfacesBase.o asynShellCommands.o asynInterposeCom.o
asynInterposeEos.o asynInterposeFlush.o asynPortDriver.o devAsynOctet.o
asynEpicsUtils.o devAsynInt32.o devAsynInt8Array.o devAsynInt16Array.o
devAsynInt32Array.o devAsynUInt32Digital.o devAsynFloat64.o
devAsynFloat32Array.o devAsynFloat64Array.o
asynRecord.o drvAsyn.o drvVxi11Win32.o E5810Reboot.o E2050Reboot.o
TDS3000Reboot.o devCommonGpib.o devSupportGpib.o boSRQonOff.o
-lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc
-lregistryIoc -ldbStaticIoc -lca -lCom  -lws2_32    -lws2_32
Creating library file: asyn.lib
asynInterposeCom.o:asynInterposeCom.c:(.text+0x6e6): undefined reference
to `_imp__pasynTrace'
asynInterposeCom.o:asynInterposeCom.c:(.text+0x14c7): undefined
reference to `_imp__pasynTrace'
asynInterposeCom.o:asynInterposeCom.c:(.text+0x1556): undefined
reference to `_imp__pasynManager'
collect2: ld returned 1 exit status
make[2]: *** [asyn.dll] Error 1
make[2]: Leaving directory `c:/modules/asyn4-18/asyn/O.win32-x86-mingw'
make[1]: *** [install.win32-x86-mingw] Error 2
make[1]: Leaving directory `c:/modules/asyn4-18/asyn'
make: *** [asyn.install] Error 2
make: Leaving directory `c:/modules/asyn4-18'
Thoughts?
AsynDriver build errors on MinGW Josh Stein
Prev: AsynDriver build errors on MinGW Josh Stein
Next: Re: AsynDriver build errors on MinGW Josh Stein
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
