1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Virtual circuit disconnect - caRepeater bug?
To: <[email protected]>, "Hill, Jeffrey O" <[email protected]>
Cc: "Stepanov, Sergey" <[email protected]>
Date: Tue, 7 Feb 2012 13:56:05 -0600
Jeff,
exactly:  this happens when a new display replaces the old display.
> There is a “feature” in the CA client library where it will close down the TCP circuit if there are no-longer any channels which use it.
Does this feature was introduced in the version 3.14.12?
Oleg Makarov
----- Original Message -----
Sent: Tuesday, February 07, 2012 1:40 PM
Subject: RE: Virtual circuit disconnect - caRepeater bug?
Hello Oleg,
Does a simple client such as camonitor experience any disconnects at the same time that MEDM does? I am guessing probably not. Have we seen this symptom with any client other than MEDM?
The message that you are seeing indicates that the OS has informed the CA client library that the TCP circuit dropped. The channels can become disconnected in the MEDM application for two reasons; the client library might detect that the TCP circuit is unresponsive or in contrast it might be informed by the OS that the TCP circuit has disconnected. It appears that you are experiencing the latter situation.
Does the circuit called out in the diagnostic in question disconnect only briefly, or do any channels connected to PVs on that IOC remain in a disconnected state?
There is a “feature” in the CA client library where it will close down the TCP circuit if there are no-longer any channels which use it. One possibility might be that a new display replaces the old display and we are seeing a timing induced false positive disconnect message when all channels on the IOC mentioned in the diagnostic are deleted. Do you know how many channels remain connected to the IOC in question before and after the related display button is pressed?
Ø  MEDM build with Epics 3.14.12.2 does not experience such "Virtual circuit disconnect"
Ø  problem while running on a workstation with Epics 3.14.11 installed.
Presumably this is occurring on Linux, with an EPICS base build specifying shareable libraries (runtime linking) for EPICS base. I seem to recall that the currently the paths to the sharable libraries are specified when MEDM is linked so this is perhaps an unexpected behavior, but perhaps that part of the build system has changed.
Jeff
Sent: Monday, February 06, 2012 7:13 PM
To: [email protected]; Hill, Jeffrey O
Subject: Virtual circuit disconnect - caRepeater bug?
Is a caRepeater bug was introduced starting from Epics 3.14.12?
It is intermittent, and may occur when "Related Display" button on an medm screen is pressed.
We were able to reproduce "Virtual circuit disconnect" message (see below) with Epics 3.14.12, Epics 3.14.12.1, and Epics 3.14.12.2 but not with Epics 3.14.11.
Other observations:
1) Workstations with Epics 3.14.11 do not experience such "Virtual circuit disconnect" problem with the same IOC, so this bug is likely on a client side.
2) MEDM build with Epics 3.14.12.2 does not experience such "Virtual circuit disconnect" problem while running on a workstation with Epics 3.14.11 installed.
Is this bug in the caRepeater code?
Any suggestions?
Oleg Makarov
Mon Feb 06 18:19:30 CST 2012
medmCAExceptionHandlerCb: Channel Access Exception:
Channel Name: Unavailable
Native Type: Unavailable
Native Count: 0
Access: Unavailable
IOC: Unavailable
Message: Virtual circuit disconnect
Context: bl3ioc1.gmca.aps.anl.gov:5064
Requested Type: TYPENOTCONN
Requested Count: 0
Source File: ../cac.cpp
Line number: 1214
RE: Virtual circuit disconnect - caRepeater bug? Hill, Jeffrey O
Virtual circuit disconnect - caRepeater bug? Oleg Makarov
Prev: RE: Virtual circuit disconnect - caRepeater bug? Hill, Jeffrey O
Next: RE: Virtual circuit disconnect - caRepeater bug? Hill, Jeffrey O
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
