g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: Virtual circuit disconnect - caRepeater bug?
To: <tech-talk@aps.anl.gov>, <johill@lanl.gov>
Date: Mon, 6 Feb 2012 20:12:44 -0600
Is a caRepeater bug was introduced starting from Epics 3.14.12?
It is intermittent, and may occur when "Related Display" button on an medm screen is pressed.
We were able to reproduce "Virtual circuit disconnect" message (see below) with Epics 3.14.12, Epics 3.14.12.1, and Epics 3.14.12.2 but not with Epics 3.14.11.
Other observations:
1) Workstations with Epics 3.14.11 do not experience such "Virtual circuit disconnect" problem with the same IOC, so this bug is likely on a client side.
2) MEDM build with Epics 3.14.12.2 does not experience such "Virtual circuit disconnect" problem while running on a workstation with Epics 3.14.11 installed.
Is this bug in the caRepeater code?
Any suggestions?
Oleg Makarov
Mon Feb 06 18:19:30 CST 2012
medmCAExceptionHandlerCb: Channel Access Exception:
Channel Name: Unavailable
Native Type: Unavailable
Native Count: 0
Access: Unavailable
IOC: Unavailable
Message: Virtual circuit disconnect
Context: bl3ioc1.gmca.aps.anl.gov:5064
Requested Type: TYPENOTCONN
Requested Count: 0
Source File: ../cac.cpp
Line number: 1214
Attachment: medm_message.png
Description: PNG image
Attachment: medm_version.png
RE: Virtual circuit disconnect - caRepeater bug? Hill, Jeffrey O
Prev: RE: EPICS IOC NFS mount and TFTP issue for the mvme3100 board, please help, urgent !!! Zhu, Lixin
Next: RE: errors in vxWorks-6.9/target/h(eader) files when building base 3.14.12.1 Vesna Samardzic-Boban
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Prev: RE: Charged Particle detectors? Mark Rivers
Next: RE: Virtual circuit disconnect - caRepeater bug? Hill, Jeffrey O
ANJ, 27 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
