1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: EPICS IOC NFS mount and TFTP issue for the mvme3100 board, please help, urgent !!!
To: Till Straumann <[email protected]>
Date: Mon, 6 Feb 2012 17:52:02 +0000
Thanks for your quick reponse,
In fact,    I only configured the 2 env varibale,
 1) mot-script-boot
 2) epics-script
MVME3100> gevShow
mot-script-boot
tftpGet -c192.168.10.9 -s192.168.10.10 -fdemo/test.boot
netShut
go
epics-script=192.168.10.10:tftpboot/demo:st.cmd
Total Number of GE Variables =2, Bytes Utilized =132, Bytes Free =3460
MVME3100>
Before the RTEMS taking control, the networking is fine. If not, the Motload can't download the test.boot into the memory, and the code runs smoothly.
I don't know how to check the networking is working or not, as the test.boot ( IOC demo)  running and taking control of the whole system , and entering the IOC shell.
I think maybe the
                              1)  the target board and nfs server  channel broken
                             2)     nfs server or tftp server side, need some specifial conifurations. It seems the RPCIOD ( nfs ) can't send data to the server side.
Sent: Monday, February 06, 2012 12:30 PM
To: Zhu, Lixin
Cc: [email protected]
Subject: Re: EPICS IOC NFS mount and TFTP issue for the mvme3100 board, please help, urgent !!!
What is your RTEMS network configuration (the 'SEND failure' and 'Can't
send...'
messages indicate that networking is not configured correctly or at all)?
Did you follow the instructions:
http://www.aps.anl.gov/epics/base/RTEMS/tutorial/node18.html#SECTION00514200000000000000
HTH
-- Till
On 02/05/2012 04:16 PM, Zhu, Lixin wrote:
>     Hi all,
>                I am a new comer for the EPICS (10 days ), and  I am now porting the RTEMS + EPICS to mvme3100 board. I meet the following case ,
>   1)      For the  NFS mode,  after i downloading a ICO simple example example.boot, it shows the following infor.
> ***** Initializing network *****
> ***** Initializing NFS *****
> RTEMS-RPCIOD $Release$, Till Straumann, Stanford/SLAC/SSRL 2002, See LICENSE file for licensing info.
> RTEMS-NFS $Release$, Till Straumann, Stanford/SLAC/SSRL 2002, See LICENSE file for licensing info.
> Trying to mount 192.168.10.10:/tftpboot/demo/iocboot/ioctest on /tftpboot/demo/iocboot/ioctest
> RPCIO: SEND failure
> Unable to contact NFS server - invalid port? (RPC: Unable to send)
> nfsMount - mount: Unknown protocol
> rtems_bsdnet_get_ntp() Can't send: Host is unreachable
> ***** Starting EPICS application *****
> Can't open /tftpboot/demo/iocboot/ioctest/st.cmd: No such file or directory
> 192.168.10.9>  pwd
>                   I can't mount the nfs server , the  st.cmd can't be called by the example.boot .
>     The  server is Debian lenny. I used another Unbuntu linux to mount the nfs server exported directory successfully .
>     Any fast method to work aroud the issue ?
> 2) Since the nfs does't work, i try to turn to the TFTP mode . however,  the error as the following ,
> vmeTsi148 - IRQ manager using VME CSR to flush FIFO
> 6 I2C devices registered
> Registering /dev/console as minor 0 (==/dev/ttyS0)
> Startup.
> ***** Initializing TFTP *****
> Can't open /TFTP/BOOTP_HOST/epics/169.254.92.2/st.cmd: No such file or directory
> 169.254.92.2>
>             I don't know wether the st.cmd file would be downloaded from the server automatically or not.  It is really no file, only empty directory.
>   Anyone who knows about this issue ?
> One of the complete log:
> Copyright Motorola Inc. 1999-2005, All Rights Reserved
> MOTLoad RTOS Version 2.0,  PAL Version 1.1 RM03
> Wed Oct 19 17:29:08 MST 2005
> MPU-Type             =MPC8540
> MPU-Int Clock Speed  =666MHz
> MPU-CCB Clock Speed  =333MHz
> MPU-DDR Clock Speed  =166MHz
> MPU-PCI Clock Speed  =66MHz, PCI, 64-bit
> MPU-Int Cache(L2) Enabled, 256KB, L2CTL =A8000300
> Reset/Boot Vector    =Flash0
> Local Memory Found   =10000000 (&268435456)
> User Download Buffer =014D3000:016D2FFF
> MVME3100>  tftpGet -c192.168.10.9 -s192.168.10.10 -fdemo/test.boot
> Network Loading from: /dev/enet0
> Loading File: demo/test.boot
> Load Address: 014D3000
> Download Buffer Size = 00200000
> Client IP Address      = 192.168.10.9
> Server IP Address      = 192.168.10.10
> Gateway IP Address     = 192.168.10.253
> Subnet IP Address Mask = 255.255.255.0
> Network File Load in Progress...
> Bytes Received =&1676364, Bytes Loaded =&1676364
> Bytes/Second   =&1676364, Elapsed Time =1 Second(s)
> MVME3100>  netShut
> /dev/enet0                 Disabled
> /dev/enet1                 Disabled
> /dev-----------------------------------------
> Welcome to rtems-4.9.3(PowerPC/Generic (no FPU)/mvme3100)
> BSP: mvme3100, CVS Release ($Name: rtems-4-9-3 $)
> CPU 0x8020 - rev 0x20
> Additionnal boot options are H
> Initial system stack at 1AB658
> Software IRQ stack starts at 1AB750 with size 16384
> Going to start PCI buses scanning and initialization
> PCI A Status: 09 : 66MHz PCI 64-bit
> PCI B Status: B8 :  33MHz PCI 64-bit
>          PMC1: ready PMC2: ready  3.3V
> PCI C Status: 09 : 66MHz PCI 64-bit
> PMC1: empty
> PMC2: empty
> PMCSpan: empty
> Build Date: Thu Apr 14 19:18:32 UTC 2011
> Board Type: MVME3100-1152 (S/N E031BAD)
> External (=PCI Bus) Clock Freq   :   66666666 Hz
> Core Complex Bus (CCB) Clock Freq:  333333330 Hz
> CPU Clock Freq:                     133333332 Hz
> Ethernet 0                  00:01:AF:31:91:9D
> Ethernet 1                  00:01:AF:31:91:9E
> Ethernet 2                  00:01:AF:31:91:9F
> Number of PCI buses found is : 2
> BUS:SLOT:FUN  VENDOR-DEV_ID: COMMAND STATUS BASE_ADDR0 BASE_ADDR1 IRQ_PIN ->  IRQ_LINE
>    0:0x00:0    0x1057-0x0008:  0x0006 0x20B0 0x80000000 0x00000000       0 ->    0 (=0x00)
>    0:0x11:0    0x10E3-0x0148:  0x0146 0x02B0 0x80100004 0x00000000       1 ->    0 (=0x00)
>    0:0x12:0    0x10B5-0x6520:  0x0147 0x02B0 0x00000000 0x00000000       0 ->    0 (=0x00)
>    0:0x14:0    0x8086-0x3200:  0x0145 0x02B0 0x00011001 0x00012001       1 ->    2 (=0x02)
>    1:0x02:0    0x10B5-0x9030:  0x0142 0x0290 0x80200000 0x00000000       1 ->    6 (=0x06)
> Memory:                             268435456 bytes
> Cleared PCI errors: pci_stat was 0x20B0
> Configuration.work_space_size = 1F4000
> OpenPIC Version 1.2 (1 CPUs and 56 IRQ sources) at 0xE1040000
> OpenPIC Vendor 0 (Unknown), Device 0 (Unknown), Stepping 0
> OpenPIC timer frequency is 41666666 Hz
> MSR is 0x00001000, TCR 0x04000000
> Exit from bspstart
> Tundra Tsi148 PCI-VME bridge detected at 0x80100000, IRQ 0
> Tsi148 Outbound Ports:
> Port  VME-Addr   Size       PCI-Adrs   Mode:
> 0:    0x20000000 0x0E000000 0xC0000000 A32, SUP, D32, SCT
> 1:    0x00000000 0x00FF0000 0xCF000000 A24, SUP, D32, SCT
> 2:    0x00000000 0x00010000 0xCFFF0000 A16, SUP, D32, SCT
> 7:    0x00000000 0x01000000 0xCE000000 CSR, SUP, D32, SCT
> Tsi148 Inbound Ports:
> 0:    0xC0000000 0x10000000 0x00000000 A32, PGM, DAT, SUP, USR, MBLT, BLT
> vmeTsi148 IRQ manager: looking for registers on VME...
> Trying to find CSR on VME...
> Startup.
> RPCIO: SEND failure
> 192.168.10.9>  pwd
>   Thank you all.
> Kevin Zhu,
> FRIB, East Lansing, US
> [email protected]
> l
Re: EPICS IOC NFS mount and TFTP issue for the mvme3100 board, please help, urgent !!! Till Straumann
EPICS IOC NFS mount and TFTP issue for the mvme3100 board, please help, urgent !!! Zhu, Lixin
Prev: Charged Particle detectors? Pierrick Hanlet
Next: RE: Charged Particle detectors? Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: EPICS IOC NFS mount and TFTP issue for the mvme3100 board, please help, urgent !!! Till Straumann
Next: Re: EPICS IOC NFS mount and TFTP issue for the mvme3100 board, please help, urgent !!! Till Straumann
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
