1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: asyn reading to waveform records
To: Rod Nussbaumer <[email protected]>
Cc: epics Techtalk <[email protected]>
Date: Wed, 1 Feb 2012 15:53:05 -0800
This might be possible, but asynOctet is not really intended to handle multi-byte values.
Trying to coerce it to do so is likely to open several wormy cans of things like endian issues and such.
On Feb 1, 2012, at 3:44 PM, Rod Nussbaumer wrote:
> Thanks, Mark & Eric. If need be, I will take that approach, although I'm really hoping I don't have to.
> Is there something I've done wrong in trying to use the waveform record in the way I've done it? It feels like I'm so close, and everything I see in the documentation and in the dbd file suggests it should be possible.
>   --  rod.
> Mark Rivers wrote:
>> I believe that Zen Szalata from SLAC has also recently written Tektronix scope support based on asynPortDriver.
>> Mark
>> -----Original Message-----
>> From: [email protected] [mailto:[email protected]] On Behalf Of Rod Nussbaumer
>> Sent: Wednesday, February 01, 2012 1:18 PM
>> To: epics Techtalk
>> Subject: asyn reading to waveform records
>> Hi All.
>> As a fallback alternative to my earlier problem reading oscilloscope
>> waveforms with StreamDevice (and to potentially reveal something about
>> the original problem), I am trying to use asyn to read the waveform into
>> a waveform record directly (without the aid of StreamDevice).
>> If I use the waveform record with FTVL=UCHAR or FTVL=CHAR, and
>> DTYP=asynOctetRead, I am able to acquire the scope binary-formatted data
>> into the waveform record, and I seem to be able to get the performance
>> that I require. However, this method gives me byte oriented data, and
>> the 'scope is sending 16-bit signed data. So, I tried using the
>> FTVL=SHORT, or FTVL=USHORT and DTYP set to any of the
>> 'asynIntXXArrayWfIn' data types. This results in iocInit reporting :
>>> devAsynInt16Array::initCommon, TEST:SCOPE1:CURVE find asynInt16Array interface failed
>> Some combinations of FTVL&  DTYP fail with messages like:
>>> devAsynInt8Array::initCommon, TEST:SCOPE1:CURVE field type must be SIGNED_TYPE or UNSIGNED_TYPE
>> My application dbd file contains:
>>> device(waveform,INST_IO,asynWfOctetCmdResponse,"asynOctetCmdResponse")
>>> device(waveform,INST_IO,asynWfOctetWriteRead,"asynOctetWriteRead")
>>> device(waveform,INST_IO,asynWfOctetRead,"asynOctetRead")
>>> device(waveform,INST_IO,asynWfOctetWrite,"asynOctetWrite")
>>> device(waveform,INST_IO,asynInt8ArrayWfIn,"asynInt8ArrayIn")
>>> device(waveform,INST_IO,asynInt8ArrayWfOut,"asynInt8ArrayOut")
>>> device(waveform,INST_IO,asynInt16ArrayWfIn,"asynInt16ArrayIn")
>>> device(waveform,INST_IO,asynInt16ArrayWfOut,"asynInt16ArrayOut")
>>> device(waveform,INST_IO,asynInt32ArrayWfIn,"asynInt32ArrayIn")
>>> device(waveform,INST_IO,asynInt32ArrayWfOut,"asynInt32ArrayOut")
>>> device(waveform,INST_IO,asynFloat32ArrayWfIn,"asynFloat32ArrayIn")
>>> device(waveform,INST_IO,asynFloat32ArrayWfOut,"asynFloat32ArrayOut")
>>> device(waveform,INST_IO,asynFloat64ArrayWfIn,"asynFloat64ArrayIn")
>>> device(waveform,INST_IO,asynFloat64ArrayWfOut,"asynFloat64ArrayOut")
>> As yet another possible fallback, is there a way to coerce the
>> byte-oriented data that I acquire to be 16-bit word data, perhaps using
>> a subarray record in some obscure way? I probably do need to use a
>> subarray record anyway, as there is a 6-byte header on the waveform,
>> which I need to drop.
>> For the record, this is EPICS 3.14.11 and Asyn R4-13 on x86 Linux.
>> Thanks.
>> Rod Nussbaumer
>> ISAC Controls, TRIUMF
>> Vancouver, Canada.
Eric Norum
[email protected]
RE: asyn reading to waveform records Mark Rivers
Re: asyn reading to waveform records Rod Nussbaumer
Prev: Re: asyn reading to waveform records Rod Nussbaumer
Next: RE: asyn reading to waveform records Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
