1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: asyn reading to waveform records
To: "'Rod Nussbaumer'" <[email protected]>, epics Techtalk <[email protected]>
Date: Wed, 1 Feb 2012 23:06:04 +0000
I believe that Zen Szalata from SLAC has also recently written Tektronix scope support based on asynPortDriver.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Rod Nussbaumer
Sent: Wednesday, February 01, 2012 1:18 PM
To: epics Techtalk
Subject: asyn reading to waveform records
Hi All.
As a fallback alternative to my earlier problem reading oscilloscope
waveforms with StreamDevice (and to potentially reveal something about
the original problem), I am trying to use asyn to read the waveform into
a waveform record directly (without the aid of StreamDevice).
If I use the waveform record with FTVL=UCHAR or FTVL=CHAR, and
DTYP=asynOctetRead, I am able to acquire the scope binary-formatted data
into the waveform record, and I seem to be able to get the performance
that I require. However, this method gives me byte oriented data, and
the 'scope is sending 16-bit signed data. So, I tried using the
FTVL=SHORT, or FTVL=USHORT and DTYP set to any of the
'asynIntXXArrayWfIn' data types. This results in iocInit reporting :
> devAsynInt16Array::initCommon, TEST:SCOPE1:CURVE find asynInt16Array interface failed
Some combinations of FTVL & DTYP fail with messages like:
> devAsynInt8Array::initCommon, TEST:SCOPE1:CURVE field type must be SIGNED_TYPE or UNSIGNED_TYPE
My application dbd file contains:
> device(waveform,INST_IO,asynWfOctetCmdResponse,"asynOctetCmdResponse")
> device(waveform,INST_IO,asynWfOctetWriteRead,"asynOctetWriteRead")
> device(waveform,INST_IO,asynWfOctetRead,"asynOctetRead")
> device(waveform,INST_IO,asynWfOctetWrite,"asynOctetWrite")
> device(waveform,INST_IO,asynInt8ArrayWfIn,"asynInt8ArrayIn")
> device(waveform,INST_IO,asynInt8ArrayWfOut,"asynInt8ArrayOut")
> device(waveform,INST_IO,asynInt16ArrayWfIn,"asynInt16ArrayIn")
> device(waveform,INST_IO,asynInt16ArrayWfOut,"asynInt16ArrayOut")
> device(waveform,INST_IO,asynInt32ArrayWfIn,"asynInt32ArrayIn")
> device(waveform,INST_IO,asynInt32ArrayWfOut,"asynInt32ArrayOut")
> device(waveform,INST_IO,asynFloat32ArrayWfIn,"asynFloat32ArrayIn")
> device(waveform,INST_IO,asynFloat32ArrayWfOut,"asynFloat32ArrayOut")
> device(waveform,INST_IO,asynFloat64ArrayWfIn,"asynFloat64ArrayIn")
> device(waveform,INST_IO,asynFloat64ArrayWfOut,"asynFloat64ArrayOut")
As yet another possible fallback, is there a way to coerce the
byte-oriented data that I acquire to be 16-bit word data, perhaps using
a subarray record in some obscure way? I probably do need to use a
subarray record anyway, as there is a 6-byte header on the waveform,
which I need to drop.
For the record, this is EPICS 3.14.11 and Asyn R4-13 on x86 Linux.
Thanks.
Rod Nussbaumer
ISAC Controls, TRIUMF
Vancouver, Canada.
Re: asyn reading to waveform records Rod Nussbaumer
RE: asyn reading to waveform records Szalata, Zenon M.
Prev: Re: asyn reading to waveform records Eric Norum
Next: Re: std_R3_1 Bruce Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: asyn reading to waveform records Rod Nussbaumer
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
