g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: asyn reading to waveform records
To: epics Techtalk <tech-talk@aps.anl.gov>
Date: Wed, 01 Feb 2012 11:18:22 -0800
Hi All.
As a fallback alternative to my earlier problem reading oscilloscope waveforms with StreamDevice (and to potentially reveal something about the original problem), I am trying to use asyn to read the waveform into a waveform record directly (without the aid of StreamDevice).
If I use the waveform record with FTVL=UCHAR or FTVL=CHAR, and DTYP=asynOctetRead, I am able to acquire the scope binary-formatted data into the waveform record, and I seem to be able to get the performance that I require. However, this method gives me byte oriented data, and the 'scope is sending 16-bit signed data. So, I tried using the FTVL=SHORT, or FTVL=USHORT and DTYP set to any of the 'asynIntXXArrayWfIn' data types. This results in iocInit reporting :
devAsynInt16Array::initCommon, TEST:SCOPE1:CURVE find asynInt16Array interface failed
Some combinations of FTVL & DTYP fail with messages like:
devAsynInt8Array::initCommon, TEST:SCOPE1:CURVE field type must be SIGNED_TYPE or UNSIGNED_TYPE
My application dbd file contains:
device(waveform,INST_IO,asynWfOctetCmdResponse,"asynOctetCmdResponse")
device(waveform,INST_IO,asynWfOctetWriteRead,"asynOctetWriteRead")
device(waveform,INST_IO,asynWfOctetRead,"asynOctetRead")
device(waveform,INST_IO,asynWfOctetWrite,"asynOctetWrite")
device(waveform,INST_IO,asynInt8ArrayWfIn,"asynInt8ArrayIn")
device(waveform,INST_IO,asynInt8ArrayWfOut,"asynInt8ArrayOut")
device(waveform,INST_IO,asynInt16ArrayWfIn,"asynInt16ArrayIn")
device(waveform,INST_IO,asynInt16ArrayWfOut,"asynInt16ArrayOut")
device(waveform,INST_IO,asynInt32ArrayWfIn,"asynInt32ArrayIn")
device(waveform,INST_IO,asynInt32ArrayWfOut,"asynInt32ArrayOut")
device(waveform,INST_IO,asynFloat32ArrayWfIn,"asynFloat32ArrayIn")
device(waveform,INST_IO,asynFloat32ArrayWfOut,"asynFloat32ArrayOut")
device(waveform,INST_IO,asynFloat64ArrayWfIn,"asynFloat64ArrayIn")
device(waveform,INST_IO,asynFloat64ArrayWfOut,"asynFloat64ArrayOut")
As yet another possible fallback, is there a way to coerce the byte-oriented data that I acquire to be 16-bit word data, perhaps using a subarray record in some obscure way? I probably do need to use a subarray record anyway, as there is a 6-byte header on the waveform, which I need to drop.
For the record, this is EPICS 3.14.11 and Asyn R4-13 on x86 Linux.
Thanks.
Rod Nussbaumer
ISAC Controls, TRIUMF
Vancouver, Canada.
Re: asyn reading to waveform records Eric Norum
RE: asyn reading to waveform records Mark Rivers
Prev: RE: mcaR7-0 Mark Rivers
Next: Re: asyn reading to waveform records Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Prev: Re: DRVL, DRVH, HOPR, LOPR Dirk Zimoch
ANJ, 27 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
