g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: 5500 temp monitor Re: mvme6100 HW issues?
To: "tech-talk@aps.anl.gov" <tech-talk@aps.anl.gov>
Date: Wed, 1 Feb 2012 12:18:14 -0500
Hi:
At SNS, we updated from the MVME2100 to the MVME5500.
The 2100 runs forever without added cooling on extender boards
in open crates in laboratory setups.
The 5500 needs forced cooling right across its heat sinks;
it will otherwise soon overheat.
Richard Dickson found a way to read a Maxim DS1621 temperature sensor
that's on the 5500 CPU board, which Xihui Chen turned into
an EPICS device driver that we now use on many 5500 CPUs to
monitor their temperature, alarming on some limit.
We could share that if you want to check possible adaption
to the 6100, or see if it's generic enough for use at your
site with 5500 boards.
Kay
Re: 5500 temp monitor Re: mvme6100 HW issues? Kate Feng
RE: mvme6100 HW issues? Allison, Stephanie
Prev: RE: mvme6100 HW issues? Allison, Stephanie
Next: RE: mcaR7-0 Szalata, Zenon M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Next: Re: 5500 temp monitor Re: mvme6100 HW issues? Kate Feng
ANJ, 27 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
