g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: mvme6100 HW issues?
From: Vesna Samardzic-Boban <Vesna.Samardzic-Boban@synchrotron.org.au>
To: "tech-talk@aps.anl.gov" <tech-talk@aps.anl.gov>
Date: Wed, 1 Feb 2012 17:47:21 +1100
Has anyone experienced HW issues with MVME6100 board (or any other MVME board)?
Recently we bought our first Motorola/Emerson MVME6100 board.
It worked fine for about a couple of months but then it would start to show errors and stop working (unresponsive).
As nothing was changed in the HW setup (only that board in the crate, the crate open, the fan ok, etc.), and the errors caught on the screen looked like given below, I believe it could be a HW fault.
Some of the errors caught on the screen:
MVME6100>
isr: CPU Bus Parity Error
isr: Reg0x78 = 000001f0, Address = 002d6ab8
isr: Data High:Low = 00000000:00000000
isr: Parity = df, Cause = 30000040
After the screen freezes, it is not possible to enter anything from the keyboard.
It happens regardless of the way i boot i.e. for both MOTLoad FW (S4 = off on on off) or vxWorks (S4 = off off off off).
I noticed the heatsink on the board is loose and possibly not mounted properly (also would get very hot) - so I just sent it back to the supplier/manufacturer.
Has anyone experienced similar problems with mvme6100 or any other mvme board?
Regards, Vesna
Vesna Samardzic-Boban | Senior Controls Engineer | Australian Synchrotron
p: (03) 8540 4238 | f: (03) 8540 4200
vesna.samardzic-boban@synchrotron.org.au | www.synchrotron.org.au
800 Blackburn Road, Clayton, Victoria 3168<br>This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you.
DRVL, DRVH, HOPR, LOPR Abadie Lana
RE: mvme6100 HW issues? Allison, Stephanie
Prev: RE: mcaR7-0 Mark Rivers
Next: Re: mvme6100 HW issues? chris.colborne
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Prev: RE: mcaR7-0 Szalata, Zenon M.
Next: DRVL, DRVH, HOPR, LOPR Abadie Lana
ANJ, 27 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
