Kay!
My CSS product is based upon the KEK 3.0.1. It has 3 features - org.csstudio.kek.eclipse.feature, org.csstudio.kek.core.feature and org.csstudio.kek.applications.feature. I have added alarms and archiving to the applications feature. This epics prefs menu resides in the core feature - org.csstudio.platform.libs.epics.ui, org.csstudio.ui.preferences and org.csstudio.ui.help. So these three are in there already, nothing to change. Still the problem exists.
On Tue, Jan 24, 2012 at 5:07 PM, Kasemir, Kay <[email protected]> wrote:
Hello Pavel:
Sounds like you are finding your way around fine so far!
The "EPICS" preference GUI and some associated online help is provided by the plugin
org.csstudio.platform.libs.ui, so you need to include that.
To get the 'anchor' points that it uses you may also need to include
-Kay
From: Pavel Masloff <[email protected]<mailto:[email protected]>>
Date: Tue, 24 Jan 2012 03:46:02 -0500
To: "[email protected]<mailto:[email protected]>" <[email protected]<mailto:[email protected]>>
Subject: [CSS] 'Epics' menu in Preferences disappeared!!!
Hello,
I was creating my own CSS application in Eclipse RCP, added some features - Alarms (Alarm Engine, Alarm Config Tool, Annunciator, JMS2RDB), dummy Auth&authorization and the Archiving system (Archive Engine, Archive Config Tool). Exported to a complete CSS application. Everything works absolutely fine, but the 'Epics' menu in Edit->Preferences->CSS core has disappeared! Of course, I can use the -pluginCustomization ini file, which i do in any case. Just thought it doesn't look nice since it's not in the Prefs anymore.
Any suggestions?
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Phone: +7 (812) 461 01 01
-- Sincerely,
Pavel Maslov, MSc R&D Institute for Electro-Physical Apparatus
Mobile: +7 (951) 672 22 19 Phone: +7 (812) 461 01 01
- Re: [CSS] 'Epics' menu in Preferences disappeared!!! Kasemir, Kay
- [CSS] 'Epics' menu in Preferences disappeared!!! Pavel Masloff
Re: errors in vxWorks-6.9/target/h(eader) files when building base 3.14.12.1 Andrew Johnson
Openning at CLS Elder Matias
<2012>
<2012>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
