1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: [CSS] 'Epics' menu in Preferences disappeared!!!
To: Pavel Masloff <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 24 Jan 2012 08:07:29 -0500
Hello Pavel:
Sounds like you are finding your way around fine so far!
The "EPICS" preference GUI and some associated online help is provided by the plugin
org.csstudio.platform.libs.ui, so you need to include that.
To get the 'anchor' points that it uses you may also need to include
org.csstudio.ui.preferences and org.csstudio.ui.help.
-Kay
From: Pavel Masloff <[email protected]<mailto:[email protected]>>
Date: Tue, 24 Jan 2012 03:46:02 -0500
To: "[email protected]<mailto:[email protected]>" <[email protected]<mailto:[email protected]>>
Subject: [CSS] 'Epics' menu in Preferences disappeared!!!
Hello,
I was creating my own CSS application in Eclipse RCP, added some features - Alarms (Alarm Engine, Alarm Config Tool, Annunciator, JMS2RDB), dummy Auth&authorization and the Archiving system (Archive Engine, Archive Config Tool). Exported to a complete CSS application. Everything works absolutely fine, but the 'Epics' menu in Edit->Preferences->CSS core has disappeared! Of course, I can use the -pluginCustomization ini file, which i do in any case. Just thought it doesn't look nice since it's not in the Prefs anymore.
Any suggestions?
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Phone: +7 (812) 461 01 01
Re: [CSS] 'Epics' menu in Preferences disappeared!!! Pavel Masloff
Prev: Re: [CSS] work without EPICS base ? Pavel Masloff
Next: Re: [CSS] work without EPICS base ? Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: [CSS] 'Epics' menu in Preferences disappeared!!! Pavel Masloff
Next: Re: [CSS] 'Epics' menu in Preferences disappeared!!! Pavel Masloff
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
